OT Ventilation idea
OT Ventilation idea
OT Ventilation idea
Sawman
>I want to try an idea. There is a product on the market that exhausts air at the basement floor level up and out of the house. It is a 2 speed fan with a humidistat. Very $$$
I believe I can make one up with an in-line fan and a few other parts.
Here is my question. I have found a fans that is rated at 52d for sound.I am at a loss on how to equate this to "level of quietness".
Would appreciate your input!
Thanks
Re: OT Ventilation idea
Normal Voice *LINK*
Dustmaker Mike
>Check out this chart
Chart
One note of caution on that chart
Tim Greif - West of Chicago
>That chart needs to be taken with the understanding that sound level (db) is relative to how far away you are from the noise source. Every time you double the distance from the source, you reduce the sound level by 6 db.
How does that relate to loudness? It's generally accepted that people report a doubling of loudness for each increase in sound level of approximately 10 dB, all else being equal.
What did you say(-; I was to far away
Dustmaker Mike
Not sure what to say.....
>Why do you need such a thing? As a Home Inspector, I have seen a few, but never saw where they made any improvement. I suspect they are one of those snake oil products based on pseudoscience.
If it sucks air off the floor and blows it outside, the same amount of air has to return to the structure. Where Si that air coming from? If it is humid inside, it's likely to be humid outside. You would often be exchanging humid air for humid air.
You would need a differential humidistat to control it well. Very expensive. Measures conditions outdoors and indoors and makes a calculation on whether to run the fan.
Man named Joe Lstiburek is a building scientist and has a web site. Building Science I think. Google him and read up.
