What is a seer rating in AC?
Ernie Miller
>A girl here at work needs a new AC in her house and just ask me what a seer rating was I looked on the internet and didn't find much more than advertisements so I thought I would ask you all for the correct answer Thanks Ernie
Re: What is a seer rating in AC?
Try this  *LINK*
Dan Donaldson
SEER ratings
Re: Dan beat me to it....
DaleLenz
>had the same page marked, : ' >. As I understand it, the higher the SEER rating the more cooling you get/unit of power, in this case watts. Was wonder if the new proposed Cash for Appliances will apply for A/C. Got a shop A/C that could be upgraded, : ' >.
Seasonal Energy Efficiency Rating *LINK*
Bill Turpin in WNC mountains
>The attached link is Wikipedia. I have read it and it is pretty accurate. All units must be at least 13. Increase from nine to 13 is a 30% savings. The higher the better, however does the increase in rating make the cost outweigh tne operational cost? Call your local electric utility for their recommendation, they will not lead you astray. Factors to consider are KWH cost, location in country, and personal habits. Returns from the expense of higher SEERs are much higher (or sooner) for people in FL, with several kids, that run the AC ten months a year. If you are 75 and are happy at 80�, and live in upstate Michigan then your payback will be much longer. Kilowatt hours at 10 cents versus 13/14 cents,the same thing is true.
SEER difinition
Jim Dillon
>Ernie,
Bill makes some excellent points. When I shopped for an AC five years ago (before the mandatory SEER of 13 went into effect), the "sweet spot" for me was around a SEER of 14. At the time, I think the SEER ratings went from 12 to 18-21 or thereabouts. But the higher SEER units are MUCH more expensive, with a much longer payback - especially if you have "cheap" electricity and live in a moderate climate. There is also a rating for heating, that works much the same way, but most folks in moderate climates don't pay much attention to that rating.
Jim
Thanks got it
Ernie Miller
>16 or better you get a tax break she it getting several estimates and should be cooled back down by the weekend.
Re: Thanks got it
Victor Parisian
>The higher the SEER rating the more humidity seems to be returned back to the room. The more humidity returned to the room the cooler you have to run the A/C in order to feel comfortable...
This may just be my imagination, but that's how it seems to me.
Victor - in Hot and Humid Houston (Fall should be for a couple of hours someday in mid November)
Some things to think about....
>Most systems are over sized. Sellers get paid "by the ton". Bigger units sell for more than smaller ones. It may be wise to look at the house as a total package. Could you upgrade the insulation, particularly in the ceiling and put in a smaller unit. There may be other things that could reduce the cooling load. Putting one or two thousand into good conservation strategies might allow you to knock out a half or even a whole ton. A smaller unit may save $500 or a $1000. This might be more effective than bumping the efficiency up to the next higher SEER. Don't be shy about keeping the unit as small as possible. Smaller units, more nearly the correct size run in longer bursts and do a better job of dehumidifying. if the unit is slightly too small you don't die, it just means that on the hottest day of the year you are slightly warmer than you wanted for a few hours. The rest of the time the unit is much more nearly the right size.
Improving the energy efficiency of the house works year round, saving money even when the AC is not running.
I would tend to lean toward standard equipment, nothing exotic. Hard to get the exotic stuff fixed.
