OT - Acronis/backing up hard drive
Paul Cates - Henderson, KY
>Will Acronis make an exact copy of a primary internal hard drive onto a second internal drive? Let me explain further: if the primary drive fails, will the second be immediately bootable? E.g., 1st drive fails, start computer and change BIOS settings to boot to slave drive, then computer boots normally and all settings, drivers, desktop icons, etc. are the same.
I have read through True Image's user guide, and I'm still confused whether it will do what I want. It talks about backup media, .tib extensions added to the backup files and so forth
The current backup software I have (Xact Copy from www.duocor.com) is freezing at the end of the backup on a fresh install of XP, so it seems I need an alternative.
Re: OT - Acronis/backing up hard drive
You want to clone not backup
Curly Smith
>Either the full version or the version of Acronis that comes with a WD drive will allow you to both clone and backup your drive. In your example, you want to clone the drive to make an exact bootable copy. The backup option will create a compressed image file that is not bootable, or usable, until it's restored.
Note that your second hard drive must be formatted as a "bootable drive".
You want to clone not backup...Yes
Chuck W
>I use a program called Drive Image that lets me make an exact clone of the bootable drive to another drive which is connected internally all the time. So that the computer will not try to boot from both drives at the same time the cloned image has to be hidden. This is done with the software. Should the day come when I need to go to the backup image I will first need to use my program to unhide the bootable partition. The copying is accomplished in DOS amd the program is on a floppy disk. There may be some freeware out there that will perform the cloning of your disk. But before you clone the drive create the bootable partition first and make it the same size as the current bootable partition.
In fact.....
Chuck W
>I can sen you the contents of each disk by email and you just have to put them on to a floppy(2 disks).
Next question - Scheduler for Automatic Cloning?
>Thanks guys - yes, cloning is what I want. Do any of these programs allow me to schedule say, weekly automatic clones? Basically, set it and forget it.
Re: Next question - Scheduler for Automatic Clonin
Bill Howatt
>True Image clones cannot be scheduled but image creation an be.
Cloning is really intended to replace an old drive with a new drive. It is not the recommended way of doing backups but it will serve that purpose just as images will alow you to transfer the system to a new drive.
The advantage of imaging is that you can have as many versions of the archives that will fit on the target device whereas you can only have 1 clone. I personally never see the reason for wanting to switch disks quickly because my experience says failures are not a common occurence and who cares if it takes a few extra minutes. If you are running a critical computer-based business then fair enough.
To to http://forum.acronis.com if you have TI questions. There is a very active support community there.
Bill
Dave Anderson (PacNW)
>What you are trying to do with software is just why they invented the "RAID ARRAY". If your motherboard has Raid capability's all you have to do is add a second hard drive, the same capacity or larger, change some settings in Bios and you have a second mirrored drive that is identical to your C\: and invisible. If your primary drive fails, the Raid drive takes over with no loss of data. Unless of course a really nasty virus caused the damage in which case both drive will have been compromised
Dave (PacNW)
You don't want to do that
Curly Smith
>Even if the Acronis Scheduler allowed you to auto-clone, which as Bill points out it doesn't, you wouldn't want to enable that option. Nor should you mirror the drive. You made a clone for at least two reasons: (1) in case your old drive physically failed and (2) in case your old drive failed to boot from either viruses or registry problems and it was unrecoverable without reformatting. If you clone or mirror a drive with a fatal virus or registry problem then the second drive will also be non-functional. Remember that registry changes only take place when you reboot so your perfectly functioning PC could have a fatal registry error that won't show up until tomorrow.
However, there is an easy solution. Since your program files seldom change, and any System or anti-virus updates can always be downloaded again, you only need to focus on your data files (which are the only important files on your PC anyway). Either of the below programs will maintain "security" copies of your data files:
Karen's Replicator 3.65
Cobian Backup 9.5.1.212
If you make the habit of always using a single directory tree for your data files (like My Documents\sub-folders for each program) then it's a simple matter to have either of the above programs monitor C:\documents and settings\ and then copy any changes to D:\documents and settings\. If you store data all over the PC then you'd need to build jobs for each specific directory tree. When you make substantial program file changes you can re-clone the drive and start the monitoring process again.
However, if your new drive has enough room then I'd also setup an Acronis backup routine and collect images for your main drive. Ideally, you'd save those on a separate partition but a directory will work.
