Caster preferences
Caster preferences
Caster preferences
>I'm going to having to make a "trolley" as a prop in a play. This is supposed to be a "tea trolley", but given the cost of the tea trolley wheels, I'm going to use regular casters.
The "trolley" is going to have to hold a young woman. The surface on which it will be rolling is a series of platforms and the stage floor and therefore is somewhat uneven. I was planning on using 3" casters. Should I consider using the rubber tired casters or just the plain polypropylene casters? Only about $1 difference.
TIA
Re: Caster preferences
Kneale Brownson..Awaiting return to CO snows
>I'd think you'll need something that will roll QUIETLY across the various joints. The larger the wheels, the easier it'll roll. You're probably talking about moving more than 100 pounds across uneven surfaces, so I'd think you'd want wheels four or five inches across with a rubber surface.
A.J. Hamler
A.J. Hamler
>I agree with Neale. From the house, the audience will never be able to tell that those casters are larger than they should be. The larger casters will handle weight better in that they'll roll far more smoothly over an uneven surface while being pushed by an actor, who really needs to be concentrating more on his character and lines than worrying about the working of the props.
I'd go with rubber, as it will grip a surface better than the hard propylene, and will be quieter to boot. Again, from the house you can't tell what they're made of.
Plus, when the show closes and you dismantle the cart, you can use the wheels in your shop.
A.J.
I built stage sets for 16 years
Forrest Addy
>I built stage sets for the local opera company for 16 yearsm some elaborate. In that time I've had some bitter lesson in casters for props and trucks under portable set pieces. The lesson I learned is to never cheap out on casters. They are a durable item salvaged from set strike and used over and over again.
I used Fell swivel caster with poly wheels with molded on urethane tires. My stave sets and prop piecess glided noiselessly and surely. The stage crew never has a problem with balky casters during set changes and anything that had to be moved on stage was smooth and predictable well withing the grasp of an actor who when in character has the IQ of a clam.
I prefer Faultless which I purchase at a local caster supply house. Never ever use home center casters on anything important. They are the cheapest item possible in the general shape of a caster and sure to fail at the worst possible time. I know. I used them on my first set and replaced them after the second performance.
Prsently you're concerned with a light load like an actress on a tea cart but always concern yourself with loading. 3" urethan over polypro casters will work fine but be careful. They often come with red tires which will be conspicuous from the front seats.
Heavy set pieces (some I've made weighed over 1000 lb) should move on phenolic caster wheels. They roll freer and survive bumps and shocks better.
Call for a "dancer's floor" (swept and mopped)on stages when set pieces have to roll on casters. Nothing worse than hitting a black construction screw invisible on a varigated floor. Sets are seldom strongly constructed and a sideways shock can rack them so doors either won't open or s-l-o-w-l-y open by themselves in the middle of a suspensful scene.
I have to ask.....
>"The "trolley" is going to have to hold a young woman."....so does that set up the line "Coffee, Tea or Me"?? ;-)
Tom
No, she's actually...
>hiding from the wife of one of the lead characters and the hotel manager.
Re: I agree with this
Bill Turpin in WNC mountains
>Remember with sets: physics and chemistry ALWAYS win. No matter what the director or the bank account wants, cheap casters will always cost you, even four years later, because you are too cheap to throw those things away. In four years of set building, we flew an adult Scrouge for ninety feet at ten feet in the air, we disappeared the witch with a bucket of water, and we put a life size train in the woods. But we never overcame the $3 casters she made us use. It is bad to put 150 hours in a set and then have to put in another 25 becuase those wheels won't turn under load.
A.J. Hamler
Well...
A.J. Hamler
>...who hasn't done that at one time or another?
I'll get reasonable casters. $9/each.
>I figure I can get a "tired" caster at HD for that.
Events will demonstrate the wisdom of HD casters.
Forrest Addy
Isn't there someone else you can ask?
>I mean..... for a question concerning casters for a theatre company, surely you can ask the casting agent ;)
Happy Woodworking!
Colonel alert!
>The competition begins.
Ask The Casting Agent
>Good Afternoon Mark,
The most accomplished casting agent I've used is Abu-Garcia. Always ready for action with superior casting. Results were reel good.
George
No competition
>The Colonel was, is and always will be the King of Puns here at Wood Central. I'm humbled by his humor, and honored just to be able to swap puns with such a Master! Long live King George!
Happy Woodworking!
See what I mean??? Amazing!!!
>Hi George,
That was a triple-pun right there! LOL
Thanks!
Happy Woodworking!
Careful Mark
>There's a fine line between casting and trolling. Both will get you hooked, but one draws flies.
Of course, George seems able to avoid the sinkers |;-}}
