Have a question? Ask Woody!
Jet Supersaw fence problem
AD
>Hi all,
I have searched through the archives but have not been able to find an answer to my problem.
I have a Jet Supersaw with the micro glide fence. This fence was ok when the saw was new but it had a habit of the locking lever popping up every now and then. This problem has gotten worse and after pushing the handle down harder and harder it snapped off ( so I replaced it with a high tensile bolt setup).
A bit of reading on the net shows that this has been an issue with this fence but I have not been able to find a fix for it yet. Jet are bloody useless and even though they are aware of the problem have no idea how to fix it except have me spend $400 plus on the Xacta fence.
Has anyone else had this problem and found a solution?
TIA
Andrew
Re: Jet Supersaw fence problem
A.J. Hamler
A.J. Hamler
>Hi Andrew...
I had the same problem with mine, and with the same result -- I snapped off the handle. I also replaced the handle as you did with a high-strength bolt epoxied inside of a custom ebony handle I turned on the lathe.
When mine started slipping I flipped the fence over and completely blew out the works with my compressor hose, as well as the track on which it rides. Now, a little bit of dust shouldn't cause a fence's locking handle to slip like that, but thoroughly cleaning out the mechanism seemed to do the trick.
At least I think so. It's quite possible that the act of turning it upside down and blowing it out may have jostled the locking mechanism just right. Also, the new handle I made allows me to lock it down very securely. It's possible the improvement is a result of all three -- jostling, cleaning and new handle. In any event, I'm not having the problem now.
And yes, that fence is junk. I love Jet equipment and am otherwise very pleased with this saw, but I sure hope they've improved the fence on the SuperSaw since I got mine.
A.J.
AD
>Thanks for the reply AJ.
I have tried all those but it still pops up at the worst possible moment. I was hoping there was a majic cure-all that another owner had found before I splash out on another fence. I'm a bit reluctant to buy another Jet fence but I have heard that there is some issues with fitting aftermarket fences to this saw so I might not have a choice.
regards,
Andrew
Kelly Anderson
>Mine did the same thing in the middle of a rip cut, scared the heck out of me. I think that I only got it to lock once or twice after that. I got the distributor to come and look at it and was able to convince him to trade it out with an xacta for the Super Saw. It is a much better fence.
Phil Joines Krum,Tx
>If Jet won't fix it then it sounds like a case for the Consumer Product Safety Communication to me.
AD
>Hi Kelly,
When you say the Xacta fence is better, would you sau it is comparable to some of the other biesmeyer style fences on the market or is it a gimmick like the micro glide fence?
regards,
Andrew
Kelly Anderson
>I meant that it is better than the Micro Glide fence. It locks and stays put and is easy to adjust for square etc. I have not used any of the other fences. In looking at the Biesemeyer fence at my local Sears on their saw I would say that it is comparable, similar design of course, quality materials but again I have never used a Biesemeyer fence.
