Re: Hvlp sprayers
>Danny,
There are many options, most depending on what you will be spraying. Woodworking finishes like solvent shellac and lacquers are in one class, next come the waterborne finishes, then on heavy oil finishes and pigmented paints of all flavors. You can consider the convenience of the all-in-one turbine units that jump in price with more power and better guns to handle heavier coatings, or go with conversion guns if you have good-sized compressor. Equipment runs from several hundred to several thousand dollars.
For instance: I started spray finishing with a 3-stage Fuji turbine unit with a bleeder gun. While it did beautifully with waterborne finishes, I had to use retarder with shellac and sanding sealer to get the material to flow out and level and the noise of the turbine and bleeder gun + the heat in the airflow and gun handle were very bothersome. I then switched to an Walcom conversion gun and pressure pot which is silent (except when the big compressor runs) and kicked my finishes to a higher level. Next, I got tired of loading (and cleaning) a 2 qt pot to do small stuff so I bought a gravity-fed mini gun that I also use for staining and toning and finishing small items and turnings.
I suppose one point to remember is that it no one gun or set-up will do everything equally well. You need to discuss what you'll be spraying as part of the what-gun-to-buy research, and ask questions pointed at that parameter. Otherwise, you're liable to get skewed info from one set of "fans" or the other who all maintain their chosen units as being better than sliced bread. My $500+ Walcom gun would suck at painting a fence, by my FIL's $30 Wagner does a great job.
Hope this helps. Be sure to call Jeff Jewitt
