Shaker Style Tables Chap.4,World's Ugliest DT's
Andy Lincoln,in Dearborn,MI
>Hi All,
I am documenting and photographing my recent project of building 8 Shaker style tables.
Chapter 4 begins the assembly process.
From Shaker Style End Tables
I set up a router with an edge guide and a dovetail bit to mortise the sockets into the tops of the legs. If I was only making one or two tables I probably wouldn�t have bothered but with 8 tables that was way too much chopping by hand for me. I did cut all the tails by hand on the front rails. As you can see by the pictures I need a lot more practice but once the tops go on no-one will ever see them and they are strictly utilitarian not cosmetic.
And anybody who tells you that they ,or you have too many clamps have never tried to assemble 8 tables all at once. I didn�t have to break into the pipe clamps but I did use a lot of my K-body clamps. Its times like these I wish I had about 10 more 24� clamps instead of having to use 31� and 40� clamps as they are heavy enough to flip a table until you get two balanced properly.
All in all it was a good day in the shop, weather was unusually cool and comfortable. Here is one of the cherry tables after being freed from the clamps.
Next steps will be drawer supports, drawers and making the tops.
Thanks For Looking,
Andy
Re: Shaker Style Tables Chap.4,World's Ugliest DT's
Comin' along, Andy
>Thanks for the update. Those dovetails will do the job just fine. It's fair enough to be meticulous, but it's more important to be realistic.
I'm curious as to whether or how you kept everything square during glue-up.
Re: Comin' along, Andy
Andy Lincoln,in Dearborn MI
>Ellis,
I assembled the tables and then measured the diagonals for squareness and put a clamp on any that were racked until the diagonals were equal.Each table is now sitting on a flat surface,such as the table saw while drying.Suprisingly they were all very close to being square as they were assembled and the dt'ed rail drove in.I think any small variances will be able to be corrected when the drawer supports and tops are fastened.I am pondering the thought of holding the lower rails up about 1/32" to 1/16" above the lower front rail so that the drawer stays a bit above and doesn't rub on the front rail.Is there a better method?A more traditional/correct method?
Andy
Victor Parisian
>That table looks very familiar. I just came in from the shop gluing mine up. Same table, same joints. I'm working on my Beta version in poplar (after many interruptions). I just attached the top to the upper front stretcher this evening or I would show you pics of my sorry dovetails. Mine are hand cut though.
Keep up the good work and keep the pics coming.
Regards,
Victor - In Hot and Humid Houston
Eight at once. You are a glutton for punishment.
Victor Parisian
>Looking good.
Victor
Joe in a Cleveland Suburb
>Nice progress Andy. Looks like a lot of work.
Jim Shaver - Oakville, Ont, Canada
>Hi Andy,
It's coming along very nicely my friend. The Dt's are strong and will work very well, these are in that class and in time you will see it is perfect for this application. Keep at it and you will only get better and better.
I enjoy your posts.
Take care,
Jim
Re: Correct method?
Kneale Brownson..Awaiting return to CO snows
>One way would be to put the runners into the sides of the drawers rather than under and hold the drawers that narrow gap above.
Will the drawer fronts be integral to the box and/or inset into the openings? You'd almost have to provide some gap in the inset instance.
Re: Correct method?
Chris Friesen
>It's been a while since I read the article, but the drawer is inset and I think the suggested technique is to plane a bevel on the lower edge of the drawer front to give a visual reveal on the bottom equal to the top and sides.
If you raise the guides slightly above the lower rail you wouldn't need the bevelled lower edge, but you would also move your support point back by the width of the lower rail, making the drawer more likely to tip forward when you pull it out.
