Woodcraft/Woodpeckers drill press table question *LINK*
wilbur
>I was thinking about getting the Woodcraft/Woodpeckers drill press table. (They are identical, except for the color of the aluminum parts.) Has anyone had an issue because of the low height of the fence on these tables compared to others that I have seen?
And I know that I could make one myself -- for various reasons, that's not a real option for me right now.
Re: Woodcraft/Woodpeckers drill press table question *LINK*
>I don't have the this table. I do prefer to have a taller fence on my drill press. It does make a difference for certain types of work. I don't know why you can't "retrofit" the Woodcraft/Woodpecker table with a higher fence - when you get around it though.
Bill Earl
>There are times when a low fence is good. Particularly when you are working close in with short bits, a tall fence interferes with the feed handles.
I built both a tall and a short fence for mine. If you don't want to build it yourself, a length of Woodpeckers "SuperTrack" and a couple of "Super Track Brackets" will make a removable riser for the low-profile fence.
Scott in Montana
>I don't mind the low fence, but I installed one of those new fangled laser cross-hair devices on my drill press.... and wouldn't you know it; even the low fence blocks the lasers.
Scott in Montana
Kenny Heermann
>I have the same setup, have no problems with the fence blocking the cross hairs. Try moving the unit higher or adjusting the cross hairs, good luck.
Alan in Little Washington (NC)
>Mount the laser to the bottom of the headstock. That gets it up really nice and high so it will shine over low fences. Plus you can swivel the headstock to drill in a different area of your sacrificial insert while the laser still tracks (which it won't do if mounted to the column).
