Help with $2 In-Table Router Lift System
Al Slitter
>Hello All;
I was very excited when I stumbled upon this article for building a cheap lift system for my table mounted router.
I purchased a Makita 3612 clone router for this purpose and followed the instructions given by Mr. Garrett Lambert. I just finished the project today and dry tested it and found a problem, when lowering the
router the threaded shaft rose upward in the bushing this is due to the filing that was done to get the threaded shaft to fit the bushing.
In the article Mr. Lambert says the following "The threads on the 3⁄8" rod are just a little too big in diameter to slide through the bushing, so with the rod back in the lathe, a coarse file quickly reduced the outside diameter of the first couple of inches to an easy slip fit through the original bushing. This little bit of filing could have been done in a vise, since there is no need for excessive accuracy. Make sure to file down enough of the threads to ensure that the rod can protrude about �" past the end of the bushing."
I allowed a little bit, about 3/8" of verticle shaft play for inserting the locking pin into the Allen head machine bolt and threaded rod. It is here that I believe the problem is at.
Has anyone else built this mechanism and if so could you please provide me with assistance.
