MS will burn you, too.
Jason Roehl in Lafayette, IN
>I've wiped my hands off with MS many times and no ill effects. The residue evaporates quickly enough (people with sensitive skin may not fare as well). The problem is when clothing absorbs solvents and prolongs the contact. Twice I've been burned. The first was early in my painting career when I spilled a little into my boot. I didn't think anything of it. Two hours later, I couldn't get home to the shower fast enough. On the way, off came the boot and sock, and I stuck my foot out the window. For two weeks, I had to wear sport shoes and low-cut socks. The second time was a rookie painter mistake, when I stuck a rag lightly dampened with MS into my back pocket. Not nearly as bad, but it smarted for a few days.
I don't know the exact chemical compositions, but I bet MS, paint thinner, kerosene in its various forms and lighter fluid are all very, very close. They all pretty much smell, look and feel the same. Some may be more purified than others, depending on the intended use, but I would guess they all come off the processing tower in about the same spot.
Jason
