WAY OT - electrical question (sort of)
John T
>Sorry for the OT post, but I'm trying to understand what just happened -
I work in my basement office, and spend my time looking into a microscope. The scope in plugged into a surge suppressor/ UPS that also supplies my computer, cable modem, printer, and wireless router.
Just a little while ago, we had a strong line of thunderstorma move through. I felt a small jolt or tingle of current through my hands (resting on the microscope) and something like a "spark" near my knee (which was about an inch away from a metal filing cabinet at the time.
Nowhere near as strong a jolt as from normal house current, but definitely more than static electricity kind of spark.
Lights didn't even flicker, the scope didn't dim, and the computer, router, and modem continued on as before. House lights and power also stayed on.
I didn't hear a sudden clap of thunder right then, either, as we had had a close-by lightening strike.
I figure there was stray voltage somehow making it through the scope, then through me, and into the filing cabinet, but I know nothing about electricity, and don't know if this is possible.
I've been doing this in the same spot for many years, and through other storms, and never has anything similar happen.
Can anyone explain what I felt, or what may have happened??
Thanks.
-John-
Re: WAY OT - electrical question (sort of)
Pete in Holland, MI
>My guess is that lighting struck some electrical stuff a ways away.
Surge protectors are not always a fix for "un-pure" 120v power, especially the cheap ones.
Best bet is to unplug electronics in a storm.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>It might be a good idea to go out to your meter and inspect to see if the ground is still in good shape.
Also, If your scope has a three prong plug, you might want to check to see if the wires on the other end of the cord are connected properly inside. Some time back in the history of the scope's life, someone may have given the cord a hard yank, pulling the ground loose, and enough to short into the housing from the hot / black wire.
Another area worth inspecting is the ground for the phone line. I was told by a couple of friends whom I have my alarm service with after lightning blew out my system, that they had seen some weird stuff, that lightning likes to surround and travel along phone lines. I have seen plenty of them poorly grounded especially on some older homes.
Other than that, it may have all been related to the cloud as it passed over your house held a huge potential for lightning, but just not quite enough for a full strike. You may have just gotten the feeder strike. If you have ever been real close to a strike, you may recall a click just before the boom. That is the feeder strike.
