Router Plate Problem
Al Goldstein
>Just finished building my router table. I used the MLCS aluminum router plate. The four allen screws in the router plate corners made adjusting the plate height very easy.
The problem is that when routing the vibration of the router plate causes the allen screws to rotate and the plate slowly drops.
I don't want to use Loctite to permanently set the allen screws - I don't like permanent solutions. Is there any substance that would prevent the allen screws from rotating and is reversible?
TIA
