What Glue to Use for Bedframe?------WebKitFormBoun
Mich B------WebKitFormBoundaryhPv+ULkWBX2gqvI9
>I shipped an antique bed frame and the shippers broke the footboard. It is an antique bedframe and the footboard is curved. There is now a hairline crack running from the top to the bottom of the footboard. I am afraid any lateral movement by persons shifting their weight on the bed (once put together) will rip the footboard in half. Therefore, I am wondering what type of glue to use which I can both get into a narrow crack with a syringe and will be strong enough to handle the weight of persons and mattress etc.
Re: What Glue to Use for Bedframe?------WebKitFormBoun
Dan Donaldson
>Depending on its age, there is a reasonable chance that an antique was originally assembled with hide glue. That is what I would use. Another reason is that it is reversible if, for some reason the first repair didn't work out. you can clean it off and try again.
Can't picture it
>I'm trying to visualize this footboard but I can't. You say it's curved, but in which dimension? Is it an Empire style that curves over or is it a solid board with a curved top? Or something else? In any case, you say the crack runs vertically. That too is puzzling, but I doubt it could affect the integrity of the bed. The weight of the people and the bedding is generally carried by the slats to the side rails.
I don't suppose you could post a little photo?
Ellis Walentine, Host
Thought it read... best glue for bedtime ??
Frank in Forest Hill
Dick Coers
>I would use titebond 1. I would also use my shop vac to pull glue through a crack. Vac hose on one side, glue applied to the other side of the wood. If you can splay the crack just slightly, the glue will pull through even easier.
Great Shop Tip, Dick
Now you tell me....
>That is a great tip. I have tried blowing glue into joints with my air compressor. That has got to be about fifty times messier than sucking it through with the shop vac. I have tried blowing it in with my mouth. Just put your lips over the crack and blow on the puddle of glue. Maybe that's why I think guacamole tastes like Elmers.
