OT - Car a/c stop leak
Joe Pack
>The AC in my 2003 TrailBlazer doesn't cool well anymore...ok on an 80 degree day, but not above that. Based on previous experience, I imagine I have leaking seals in the system.
I stopped in at an auto parts store today and saw a couple of products by EFProducts that claimed to be effective at sealing leaks in the system. One was a sealer, SuperSeal. The other was a can of R134a with sealer included. and them there was their Synthetic AC Booster.
Does any one have any experience with these products? Do they work? My GM dealer wants to fill the system to spec and add dye to find the leak(s). That would cost me about $150, then the cost of the actual repair to the seals. Simply adding R134 is much cheaper if I can seal the leaks.
Re: OT - Car a/c stop leak
Just went thru all that
Gil Jones...Georgia
>on my 1996 GMC Suburban. First of all, it is a turbo-diesel, and I stopped driving it when the cost of diesel fuel went sky-hi. So it sat in the garage for 4+ + months. The A/C was zip when I drove it a month ago, so took it to a very good, independent mechanic for troubleshooting and leak finding. They pumped the system down, filled it up with Freon and a good leak detector fluid. After nearly a week of checking and waiting, they determined that it had NO LEAKS. The story is that if the A/C system is not used, the compressor shaft and its seal loose all oil just from sitting there unused. With no oil on the shaft and its seal, the seal starts to leak. So for $140 it is COOL again, and even if I do not drive it much, I need to drive it and run the A/C at least once per week to keep the compressor shaft/seal well oiled.
They also said that GMC recommends that NO A/C system leak sealer be used as it is NOT good for the compressor.
Re: Just went thru all that
Joseph Mulherin, Sr
>I totally agree with Gil, do not use any of those sealers because they will cause you problems in the future you do not want. Have an A/C mechanic go over the system and repair what is needed....and like Gil saud...run the a/c at least once a week all year...even in the winterto keep the seals lubricated.
Well....
Bill Howatt
>I am a person who usually says do what the manufacturer suggests but I had a Blazer that developed a very samll leak. Educated guess said that it was likely in the cooling coil and cost to fix was very high. Considering the age of the vehicle I went with the non-dealer's recommendation of some sealing stuff. Worked like a charm and was still going at least 6 years after the "repair".
If your vehicle stlll has value, I'd do the proper repair suggestion first though.
Bill
