frame & panel joints
mike vance
>does anyone else strengthen kitchen cabinet doors (frame & panel) with tenons? i've been using beadlock method and was generally satisfied with results but it's fairly slow (lots of drilling). was considering loose tenons (festool domino, leigh's mortise jig, mortise pal or ?). curious if anyone has compared to beadlock.
Re: frame & panel joints
Walt
>I use the Festool Domino for door frames, face frames, indoor and outdoor furniture construction. I think it is a wonderful tool...it is quick and easy to use.
Fred Davis
>Kitchen cabinets,,, I use Biscuits for Face Frames and doors.
Once your accustomed , you will find it a much faster method.
FredD
Bill Earl
>I've used beadlock and biscuits, as well as various doweling jigs & hollow chisel mortisers. I finally bought a horizontal slot mortiser (Rojek) and never looked back.
The slot mortiser is quicker than beadlock or hollow chisels, and is capable of a stronger joint than dowels or biscuits. Had the Domino existed at the time, I might have given it a try. There are times when the Domino would probably be even quicker than the slot mortiser, but it is limited to fairly small joints.
If cabinet doors are your bread & butter, the Domino might be the tool for the job. If you need to make larger joins, I'd consider a slot mortiser.
Bob Boswood
>I'm not a pro by any means, but have built a few kitchens with shaker style cabinet doors. I built frame and panel doors using a t&g joint. I have had no failures as of yet. One kitchen is over 10 years old. If I am heading for disaster, someone please let me know. Doors are comprised of 3 inch rails and stiles with 1/2" plywood panels.
Bob in AK.
Rick L
Re: On the right track... *LINK*
Rick L
>Slot mortiser is the best. With a traditional slot mortiser you can go with loose tenons or even use it as a doweling machine...the lower rpm is much more versatile than a router. Even a doweling jig would be faster than the Beadlock. You don't need much more to make the joint stronger. I have seen plenty of broken cope and stick joints from over zealous users, especially kids!
Reinforcing cope and stick joints
Dave Bair, Eaton Rapids, MI
>If your panels are plywood, you can glue them into frame for a super-strong door.
