Can drawer slides be mounted at different heights?
>We're ramping up to remodel our second bathroom, and are struggling with a storage issue. We'd like to store small stuff efficiently under the sink, and would love drawers, but the space beside the sink drain/water lines will be limited. I'm considering a "drawer" that would work like those pull-out spice rack thingies in kitchens: a tall box, open on the side, with shelves in it, that you pull out and reach in from the side. The bad drawing below shows it in section, looking at it from the front.
There is hardware for this kind of thing, but it's (a) expensive and (b) space-consuming. I'm wondering whether I can mount drawer slides at different heights, as shown in the drawing, to support the box. Is there some reason they need to be at the same height to work well?
Re: Can drawer slides be mounted at different heights?
Thomas S Stockton------WebKitFormBoundaryRU4sWQOIA
>Bill
Shouldn't have any problem. You could also mount both of them on the tall side if the bottom is rigid enough not to sag.
Tom
GalenV in Iowa
>Tom
Am I wrong:
Drawers guides are normally designed for vertical load along the rail. If you put both of them on the "long" side then all the shelves would be cantilevered and would put side load on the rails. (Like hinges on a door) Cheap rails and high load would just pop the top off the track over time.
Only problem I see as drawn in the setup is just getting the load equal on the rails and the drawer running square to front of the cabinet.
Galen
John McGaw
>It should work fine, especially if you are using good slides. In building my kitchen cabinets I put in a slide-out compartment that fills an awkward space beside the range. It spans the whole height of the lower cabinets and has a utensil compartment open from the top and a pan compartment open toward the range side. This necessitated one slide up top on one side and one all the way at the bottom at the other but, despite heavy loads and frequent use, it has lasted for 11 years without problems. Oh, I used heavy-duty ball bearing slides but my load, what with the weight of the slideout and contents, is certainly in the 40-pound range.
Jim Dillon
>Bill,
I agree with the others that there should be no problem. I've put quality slides on the bottom, and more or less in the middle with no problem at all. I also believe that putting the two slides on the same side will work just as well. You could even put another pull out on the opposite side for a "his" and "hers" arrangement, or whatever. Lee Valley sells quality slides in white or black that I have used where I thought white might look better than the regular metal color.
Jim
Henry (Raleigh NC)
>Bill - no expertise here - but I have a question.
Is there some reason why you can't use both slides at the bottom of the open box/drawer? That would seem to be a fairly conventional installation, even if the box is open sided.
Henry
hwynands@ieee.org
>Bill
Tom
------WebKitFormBoundaryknv+qWeJhB3DkqlZ
Good question - might work
>I guess my thinking was that, because there is inevitably play in the slides, having both slides at the bottom could result in a "drawer" that rocked side to side because it would be so tall in relation to its width.
Still experimenting in my head. I need to start drawing and determining dimensions.
Hamish
>Bill,
I think the only requisite is that the slides should be parallel to each other in whatever position you mount them in the end, in order that there will be no racking of the drawer.
Regards, Hamish.
Re: Good question - might work
Gary Camp Bend, Oregon
>Use three, two on the bottom and one on the top, I know it may be overkill, but it wouldn't rock.
glc
Re: You betcha!
Brian in Brighton
>You absolutely can mount them the way you show.
Brian in Brighton
