Re: Farmers use Tordon RTU
Fred Davis
>We use Tordon every couple of years , it is a stump killer , used on tree stumps freshly cut.
Properly used , does not harm nearby plants or trees
FredD
Home > Plant Health Care > Herbicides > Tordon RTU Squirt Bottle
Great Product!
Tordon� RTU specialty herbicide effectively kills cut stumps when you are cleaning out fence lines and non-cropland areas. RTU stands for Ready-To-Use, and that's just what it is. No mixing or measuring is required, and you can use it nearly year-round. Comes in a convenient one quart squirt bottle applicator.
View Label
MSDS
Availability: In Stock
Price: $19.00
One Quart $19.00 Case of Twelve $195.00
Add to Wish List
Ask An ExpertReviews
Rob from Benton Harbor asked:
Q. Will Tordon kill Bamboo?
The TreeStuff Experts answered:
A. Tordon would be an effective herbicide choice for killing unwanted bamboo. Cut the plant low to the ground and apply a small amount of the product to the cut surface.
Mike from Pasadena, CA asked:
Q. A yucca plant is growing up against my foundation. What will be the best and easiest way to remove it without a backhoe?
A. We recommend using a saw to cut the plant as low to the ground as possible. Apply a small amount of Tordon to the newly cut surface. The plant will die and not grow back. It should eventually decompose naturally.
Glenn from Dassel, MN asked:
Q. I removed a tree one month ago and it is starting to grow back out from the stump. Will the Tordon still be effective if I apply it now?
A. Yes. Cut off the new shoots and apply the Tordon as you normally would to the stump.
Jim from Madison, AL asked:
Q. After killing the stump will Tordon poison the area for other plants? If so, for how long?
A. If used properly Tordon will not prevent another plant from growing in the same area. It is important to apply the Tordon directly to the cut plant surface. There should not be any run off.
Randy from Lyons, GA asked:
Q. Will Tordon kill roots and any growth from them?
A. Yes, Tordon will kill roots, although they can be more difficult to kill than stumps. One method is to cut the growth coming off the root and apply the Tordon to the cut surface. If you are able to apply the Tordon to the root itself it is even more effective.
Frank from Louisville, KY asked:
Q. Will Tordon kill honeysuckle?
A. Tordon would be an effective herbicide choice for honeysuckle. Cut the plant low to the ground and apply a small amount of the product to the stump.
Dan from Port Charlotte, FL asked:
Q. Will Tordon kill stumps without drilling into them and filling in center of the stumps?
A. Tordon is a powerful herbicide. The stumps will not shoot back out after Tordon is applied. However, Tordon will not dissolve the stumps or cause them to biodegrade any faster than normal.
Randy from Morristown, MN asked:
Q. Will Tordon work on the cut branches of a weeping willow tree? They grow back like crazy.
A. Tordon is a very effective herbicide. We would not recommend using it on a plant you do not wish to kill.
Submit your question to the TreeStuff experts if you don't already see an answer to your question above.
average customer rating based on 1 review
This stuff works great - 07/10/2009
Reviewer: M Sevcik
Used this on an acre of locust & hedge trees here in NE Kansas. Cut the trees at ground level and immediately applied the Tordon RTU (very small amounts) just enought to get the stump wet. I think I got very near 100% kill rate and importantly, no damage to the grass around the tree stumps. Strongly recomment this product.
