OT - light bulbs with large (mogul) bases
>The mogul based light bulbs I can find around here (at the Home Depot) are clear 400 W metal halide. Not cheap ($29). I need to replace 5 bulbs which are incandescent bulbs (500 W, frosted floods). These run about $19 each, but I have to pay shipping, etc.
Will I get enough extended life or light out of a metal halide to justify their purchase? These are for use in 16" "scoop" fixtures.
Re: OT - light bulbs with large (mogul) bases
Phil Joines Krum,Tx
>I don't think a metal halide lamp will work without a ballast. It is the same base as an incandescent but not compatible. The local Ace hardware carries them.
Re: OT - light bulbs with large (mogul) bases *LINK*
John McGaw
>Do you mean floods as in photo floods? It is possible to buy high-temperature adapters which will allow standard bulbs to fit into the old mogul base. Standard-base photo flood bulbs are expensive enough (I use a few myself) but I'm sure that they will be cheaper than the specialized mogul type.
Example of Adapter
>Similar to photo floods - I suppose they must be photo floods. They look something like this. The old bulbs are 500 W mogul base frosted floods.
John McGaw
>Looks virtually identical to the scoops I used to use in the TV studio.
Thanks for the info...
>Now I won't have to worry about buying at the Home Depot!
Found three adapters (mogul to medium)
>at a local hardware store. They will order me some more. They only wanted $2.75 each.
