We value your privacy.
>Help! I'm coming unhinged! I am building a small box for a customer, and I am installing Brusso hinges on the lid. The screws are these itty bitty #2 brass screws. I do not have a Vix bit small enough to do these holes properly, so I am looking for some guidance here.
For those of you who actually do this: What do you use?
I use a Gimlet for screws that small. Remember to drive in some steel screws first. Those tiny buggers from Brusso snap if you look at them cross eyed.
>Thanks Brent. I did a search for gimlets, and no one has anything smaller than 5/64". That works out to 0.078". According to the charts, these screws have a diameter of 0.086". That leaves 4/1000" on either side of the screw to hold it in. I already tried my 5/64" vix bit and the screw just sort of fell into the hole. I can, of course, drill these holes with a 1/16" bit, but I was hoping for some additional accuracy with the placing thereof.
>with stop-blocks on either side is what I used with a little bit for a two hinge install. As mentioned, a "prescrew" with steel self-taping thread preps the hole. Set-up needs a good mic and a couple of test pieces, but move the press table and you're SOL.
Alternative on a vix is to use CA in the hole and actually glue the screw in place.
>Assuming you know where the hinges are supposed to go, I'd eyeball the centers of the screw holes and make an accurately placed dimple for each with an awl. Follow up with a drill bit that is larger in diameter than the root diameter of the screws but smaller than the outside diameter of the threads. If the screws are tapered, you might want to taper the holes to match by rocking a little nail around in the hole. Depending on the wood, you should be good to go, but it doesn't hurt to tap the threads in advance with a steel screw, if you can find one with the same pitch and diameter as your brass ones. Use a little wax on the threads when you install the screws and be sensitive to how much torque you are applying with your screwdriver.
You could try grinding you vix bit down a little if you are willing to replace the bit later. Just chuck the bit in a drill and grind the side of it to a taper. With a hole this small, you can drill the hole with almost anything. I have chuck a tiny finishing nail (4d) and drilled with that.
Depending on the wood, Ellis is right. You can eyeball them, but I find they walk off the hard parts of the grain.
Also, I find this to be one of the best uses for my drill that has the clutch. I set it on 1 or 2 and find it will successfully drive the screws, but not snap them off. I've got a box full of snapped screws I did by hand.
I also have a self centering punch that was designed for larger screws, but I ground it down. Made the cone on the bottom smaller and sharpened the punch. Many times, that alone will do the job, but in hard wood with very fine grain there is enough slop in the plunger to allow it to deflect out of center.
Sometimes I have had luck with using a Starret hinge punch to place a starting indent in the center of the Brusso hinge hole, then use a small drill bit mounted in a drill press to finish up. Works fine sometimes, then at other times I think I could do just as well by eye with an awl, plus the grain can drive the indenter to the side. The Starret tool is not inexpensive, and only partially fits into the small hinge hole of that size hinge, so it is not a really satisfactory solution. I wish someone did make a tool or had a good solution for doing this. As an aside, I have found the Starret set of mini-screw drivers to be superb for driving those small brass screws (plus fixing eyeglasses 8-)).
>Bill, I use the smallest of the set Lee Valley sells. I've never had a problem with loose screws, and I've used more than a few of the small Brusso hinges.
>Thanks for the responses everyone! I am probably going to try the Dremel method simply because that is what I have on hand, but the gimlets look good for an addition to the shop. Some of you might be shocked - shocked I say! - with the number of hand tools that have crept into my inventory, and actually get used!
The hinges are mortised into both the box and the lid, so even if the holes go off center a little, it probably won't be a problem. And I have used the steel screw first trick for years, so I know about that one. I do appreciate everyone who took the time to reply.
I was catching up on some reading tonight and read the "Master Class" in the latest issue of FWW (#207). The author shows using just an awl to punch an indent for installing a Brusso quadrant hinge. Granted, a quadrant hinge is larger than what you would like to do, but it might work just fine.
>I have been known to stick a counter sink in the hole in the hinge and run it gently. If you have one that is "pointy" it should mike a nicely centered indention for the bit. Might run it backwards to avoid drilling out the hinge. OTOH, if there is enough room, drill out the hinges and install number 4 screws. They are huge. (Compared to the number 2's)
>I'll tell you Jesper, it ain't easy! And over torquing them? I can do that even when I am working hard to keep it light and easy. I usually buy spares right before I install them, just in case something goes wrong.
>You can get a cheap set at HF and should have one the size of the hole in the hinge. Makes a nice little indent for starting a small drill. Isn't this what transfer punches are designed for ?
>The other thing he mentions is that he purposely offsets the screw holes for the hinges so that when they go in, they pull the hinge snug with the side of the mortise.
