Firewire question.....
Chuck W
>Can i use the firewire connection like a LAN connection? The problem is I am trying now to install XP on a laptop and it is missing many drivers including the ethernet connection. is there such a thing as a crossover cable for firewire?
Re: Firewire question.....
Not in my experience
>My son and I tried wiring computers directly together without any luck. I'm not saying it can't be done, but we ended up using firewire to connect to an external hard drive and used that to bootleg the necessary files to the other computer. You get the benefit of the fast transfer speed, but you have to wait twice for the transfer.
Let me know if you figure out another way.
Andy Lincoln,in Dearborn,MI
>Chuck,
I can't answer the firewire question but I have had luck just using a USB flash drive to load drivers and such on and then plug into the next computer and load from there.
Andy
IEEE 1394 Secondary Standard
Dustmaker Mike
>is for TCP/IP or networking. So yes you can hook it up as a network in fact I use it that way all the time.
Now if you want to use it to browse the Internet to get drivers and stuff I have not seen that done.
I would look up IEEE 1394 Networking and see what you can find. I assume you can get to the internet because you posted this question.
