bed plans
bed plans
bed plans
J.C.
>Need to make a bed with drawers under the bed. It is going under a twin bed. I just can not get the ideas on paper. Any help would be nice. Thank you.
Re: bed plans
Re: bed plans
>Not quite clear what you need. Do you need plans for a drawer unit that will fit under a twin bed? Or do you need plans for a "trundle" bed with a drawer unit that will fit under a twin bed? Or do you need plans for a "trundle" bed that looks like a drawer unit that would fit under a twin bed?
The drawer unit is easy. The trundle beds are a bit harder.
Re: bed plans
Re: bed plans
Walt
>Is this the type of bed design that you want to build? If this is the style that you want to build send me your address and I will mail you the plans.
Re: bed plans
Re: bed plans, another idea.
Hamish
>JC, I once made a double bed with three deep drawers underneath to hold bed linen, quilts, pillows etc,.. The drawers were not actually fixed to the bed but rather were set on wheels making it possible to remove them completely when desired. When fitting them, I positioned some wooden guides on the bed frame in order to position them as they slotted under the bed. It was quite a basic arrangement but has stood the test of time.
Now for another idea. We have recently changed our bedroom and I would like to make another "better" bed and am strongly considering making a lift up base, in order to gain access to the space underneath. Now why am I going to do this? Well despite describing the spacious pull out drawers above, I found that they have one big disadvantage and that is that we often seem to have clutter tucked up against the bed base on the floor making access to them difficult. They also need a large clear space in front of them in order for them to be pulled right out. (I know we ought to have a spotlessly clean bedroom but there always seems to be something in the way).
Now to the lifting mechanism for our new bed. I have seen some gas shock absorber types that take most of the weight of the base board and mattress. I think this way will make it easier for us to see the contents under the bed than if we were having drawers. So the bed base will be made out of strong ply on all sides and the lifting mechanism attached to that. The top or bed base board, will overhang the base by a few inches to give toe room all around for when you are standing beside the bed.
I hope this will give you another idea to think about.
Cheers, Hamish.
