finishing purpleheart
al hillier
>HI,
I am making a large cross (8') for a chapel. It will be about 10' off the floor. I have made plywood boxes for the vertical portion and horizontal bar. I will be gluing 1/2" purpleheart over the plywood.
I plan to use my HVLP gun to spray gloss lacquer. It has been several years since I sprayed lacquer and have never finishined purpleheart. Any tips would be appreciated.
Specific questions include: Do I need to use a paste filler? How many coats should I spray at what intervals? Should I sand between coats? Should I sand final coat and if so, with what grits (i.e., 1000, 1500? etc). As well as other tips I have not thought to ask. Many thanks.
Al Hillier
Re: finishing purpleheart
avoding disaster
Bill Tindall, E.TN
>You will of course practice the finishing schedule on something besides the finished product? And practice spraying on a piece of cardboard until you get it right?
Too often woodworkers presume the hard part of making something is, well, making it. They get to the finishing part and presume that part should be easy and forge ahead hoping all will be well. So wrong. It is as difficult to properly spray a finish as to hand cut dovetails. Would one attempt dovetails without practice? Finishing a practice piece is like making a test cut for a new machine set up. Would anyone set up a machine and immediately cut the finished lumber? Well, from the questions that get asked on this forum about fixing finishing disasters, practicing a new finish schedule is not as common as it should be.
To answer your specific questions : Do I need to use a paste filler? No How many coats should I spray........2 for this appplication at what intervals.........don't understand the question ? Should I sand between coats? Yes, 320-400 stearated paper or 4/0 wool. Should I sand final coat ........not for this application As well as other tips I have not thought to ask............. PRACTICE
>My lacquer finishing schedule:
1. Sand to 180 or 220
2. Spray a light coat of finish
3. Rub out any nibs or fuzz with a maroon pad
4. Spray several full wet coats, letting each coat flash off before the next. Apply as many coats as necessary to get the visual build you're satisfied with. Don't sand between coats.
5. Finish up with a coat of 90% reducer to even out the sheen.
I usually use Sherwin-Williams SHER-WOOD� Moisture Resistant Lacquer
T70F22 Medium rubbed effect for its clarity, sheen, and ease uf use.
Clint
I question the construction
>1/2" dimension stock is lumber, not veneer. If you wrap an immobile plywood box with lumber, you run the very real risk of having it crack or blow apart at some point. I wouldn't build the cross this way, but maybe you have your bases covered somehow.
If you want to veneer the cross, that is more acceptable construction. In that case, you'd start with a good quality plywood and veneer it in stages -- opposite sides glued at the same time. Don't use contact cement whatever you do.
The alternative is to use solid purpleheart lumber and lock-miter construction of some sort. It would be heavy and a lot more expensive, but it wouldn't chip like veneer can, although a cross on the wall of a church isn't likely to get much abuse. The cross joinery would be an interesting puzzle, but it should be pretty easy to do.
Finishing shouldn't be a problem with the lacquer you mentioned, but, as Bill says, you need to have the technique down before you start spraying the actual project. Keep in mind that the bright purple color will turn to a darker purple-brown over time. It's still pretty but not dramatic like fresh purpleheart.
Ellis Walentine, Host
You are right, Ellis...
Howard Acheson
>... anything thicker than 1/8" will be problematic. Even 1/8" can sometimes lead to troubles with wood movement.
