Re: or tables not coplanar
Dave Mount
>If Ellis' suggestion doesn't help, another possibility is that the tables are not co-planar. If the end (away from the cutterhead) is high, meaning the tables make an incredibly shallow "V" with the low spot at the cutterhead, the resulting cut will be an edge that is convex along its length. I bought a Sunhill jointer years ago that had this problem.
The reason this causes a convex edge can be thought through pretty easily. Draw a picture with an exaggerated V, then draw in a board at the beginning, middle, and end of a cut. The cut starts at normal depth, but as the leading edge of the board moves out over the outfeed table, the "V" causes the middle of the board to bridge up a little, making the cut shallower. As you finish the cut, the trailing edge comes into line with the outfeed table and the cut finishes full depth. The sum of these events is a convex edge.
To diagnose this you need a reasonably long straightedge. I had a Delta Unifence at one time and that extrusion is remarkably straight, if you don't have a straightedge. Set the infeed table just slightly below the outfeed (i.e., a few thousandths), roll the cutterhead so the knives are out of the way, put the straightedge flat on the outfeed table and cantilevered out over the infeed table, and use a feeler gauge to check that the gap between the straightedge and the infeed table is consistent across its length.
If you have a problem, it can be easily remedied by loosening the upper gib screws very slightly (assuming this machine has dovetailed ways)on both sides. This allows the oufeed table to sag back a little, straightening out the "V". It doesn't take much. You could theoretically loosen the gibs on the infeed side to the same effect, but I think the outfeed is a better choice because you rarely adjust it and I think it's better to keep the infeed gibs snug. You can also adjust planarity of the tables in parallelogram machines, but I forget how. If you diagnose non-co-planar tables and don't see how to remedy that, call Grizzly tech support and have them send you directions.
The opposite problem, sagging tables, and also be cured either through adjusting the gib screws or by putting some brass shim stock under the lower end of the ways.
While you're at it, check to make sure the tables themselves are reasonably flat. If memory serves, the typcial table flatness spec for import jointer tables is like 0.003 or 0.004 inches.
And, as long as you're supertuning your jointer, check to the be sure the cutterhead is in the same plane as your tables (this is important if you set your knives with a jig that registers to your cutterhead, as is supplied with most import jointers; if you have a magnetic setter that registers off the table, the knives are automatically aligned with the outfeed table by the setting jig). Make a "hop stick" by making a short piece of wood (say 3/4" by 1.5" by 10" long)that is straight on one edge. Even though your jointer is not making perfectly straight edges, it's probably straight enough for this purpose. Mark the straight edge, then make a pencil mark across the face 90 degrees to the straight edge about 3" from one end. Move the infeed table down all the way to get it out of your way. Place the hop stick with the straight edge down and the pencil lin aligned with the edge of the outfeed table and the 3" side cantilevered out over the cutterhead. Roll the cutterhead so one knife passes the hopstick. The knive should contact the hop stick, lift it up and carry it forward a short distance. The amount the hop stick moves is proportional to (though not the same as) the amount the knife is sticking up above the table. I figured out one time by geometry that the desirable amount of movement for a 3" diameter cutterhead is 3/16" of an inch of hop stick travel. Test the knife projection with the hopstick at both sides of the cutterhead and in the middle, and do this with all three (or four) knives. If all the knives read the same, side to side and between the knives, you're golden. All you need to do then is adjust the outfeed table so you get about 3/16" of movement out of the hopstick (don't drive yourself nuts -- anything 1/8" to 5/16" is probably fine). If all of the knives are the same, but don't read the same side to side, then the cutterhead is out of alignment. You can fix this by putting a brass shim under the bearing or by adjusting the outfeed table by adjusting the gibs or adding a shim on the appropriate side. The decision between these depends on whether your infeed and outfeed tables are co-planar side to side (if they are, adjust the cutterhead; otherwise, adjust whichever table is not aligned with the cutterhead).
If you're getting scalloped cuts, the hop stick will quickly tell you which knife is out of alignment.
All of this checking and adjusting can sound a little intimidating, but it's not. Messing with jointers seems spooky to many people, but it's really straightforward. Not only will you love what a properly adjusted jointer will do for you, but if/when something goes wrong in the future, it'll be a snap to figure it out and fix it, rather than worrying about it.
Best,
Dave
