2 questions for the "pros" ;-)
Terry Alexander
>1. Can you recommend a glue with a "long" open time? I need to join 2 pieces of wood 16' long with biscuits on both sides. So...about 32 biscuits. I have Titebond regular, Titebond II, and Titebond III (my favorite glue...obviously).
2. What is the best way to get old glue off of my Bessy's? The glue (surprise) it Titebond.
As always....TIA
Terry Alexander in West Texas
Re: 2 questions for the "pros" ;-)
Glenn Madsen near San Francisco
>1. Titebond I Extend. And glue early in the morning, when the air, and project, are cool(er). Your local hardware seller should have it on the shelf.
2. Try some white vinegar, or similar weak acid. That's the rumor I recall. Then, I always chip my glue off with very expensive chisel blades...
I've been using Titebond Liquid Hide Glue lately, and just bought another pint this morning. Not for everything, but it works quite well for much of what I'm doing these days. And cleans up easily.
Alan Young
Alan Young
>Waiting to see what it isn't for.
Alan
White glue
Kelby
>Regular ol' Elmers.
Highly underrated and underused in furnituremaking.
warning
Bill Tindall, E.TN
>If the surface of any of these glue suggestions dries before assembly the joint will be weak. Get help, invent a fast glue applicator and consider whether you need biscuits. Why do you need biscuits?
Re: warning
>Terry, I'm with Bill on this.
Are you edge gluing two pieces 16' long to each other? What in the world are 32 biscuits for? They add little or no strength to such a joint and add a number of complications, not the least of which is slowing the process down. If I were doing this and I felt I had to have biscuits for alignment I might put 6 or 8. I have one of those daubers that puts the glue in the slot and I might use that or I might just put them in the slots dry. Then I would roll my glue on the other surface with a roller bottle and stick the pieces together and put on the clamps. Would use a block of wood or rubber mallet to tap the pieces into nice alignment as I snugged the clamps. If you get the clamps set up and the work laid out, this is not a terribly complicated glue up and you should be able to get it done in under ten minutes which I think is the open time for any of the glues you mentioned.
I might do a dry run. Lay it out, clamp up the pieces without glue, see if they line up nicely, make my adjustments, back off the clamps and glue it. If the two pieces are the same width I would stand them on edge side by side and apply glue to both at the same time. Or you could use hand clamps to hold them side by side and level to apply the glue. I usually don't bother with the dauber and roller bottle. Just apply the glue and smear it with a stick. Enough falls in the slots for the biscuits (which I seldom use anymore), stick in the biscuits and lay the pieces down and clamp them.
More choices
Ed Mulligan
>Weldwood Resorcinol (powder mixed with water), WEST slow set epoxy (two part resin and hardener), Unibond 800 (mix resin and powder).
All of these require good ventilation or a suitable respirator. Say goodbye to worries about open times and skin-over.
I use Unibond for veneering, West epoxy for most other long open time situations, resorcinol if low cost is wanted.
Titebond and other 'yellow glue' and 'white glue' products are great stuff but sometimes their quick 'grab' makes them unsuitable for a particular job.
Cleanup varies by product. Make sure you allow for appropriate cleanup before using.
>Way too many biscuits; 5 or 6 will assure decent registration, which is their primary value. Set them all on one side in a little glue for glueup. Run a continuous bead of any Titebond on the edge of other piece. Don't bother spreading the glue; clamping will do it for you.
Clint
Jim Dillon
>Hi Terry,
Not a "pro" by a long measure, but I have used Titebond Extend (sounds like one of those ubiquitous TV ads 8-)), as well as Lee Valleys's cabinet glue with a longer working time. I thought LV's glue was pretty darn runny, the Titebond less so.
I also vote for fewer biscuits. Sometimes I just run a single bead of glue down the entire edge, with some going into the biscuit holes. I don't bother spreading out the glue in the biscuit holes, but do quickly run my finger along the entire edge surface to spread the glue out. Then insert the biscuits, slide the other board into place and clamp up. If I have the time, I do apply a THIN layer of glue to the opposite board, and into the biscuit holes. Hope this helps.
Jim
That's what Frank Klausz uses
>... for most of his work, including some pretty complicated glue-ups like the workbenches we made a few years back.
Why I'm doing this.....
Terry Alexander
>I am wainscoating (sic?) my game (pool table) room. The top and bottom section is 3/4" MDF, the next section is 1/2" MDF and the middle sections (kind of a square) is 1/4" luan. The luan fits in a rabbet in the 1/2" MDF. The biscuits are to attach the 3/4" and 1/2" top and bottom and then the vertical separators (stiles more or less) is 1/2" MDF and is biscuited to join the top and bottom.
The only reason I picked 16-32 biscuits is that Norm (yep....that's where I got most of these ideas) puts biscuits every 8". I was only going to put a biscuit every 12". So, on a 16' wall. I'll need 32 biscuits to join top 3/4" to 1/2" and same on the bottom. I will need another 20 biscuits (10 each for the top joint and bottom joint) to attached the separators.
I am open to any (and all) design questions/comments.
Thanks guys.....now....about removing glue from my Bessey's ;-)
Re: Why I'm doing this.....
Andy Lincoln,in Dearborn,MI
>terry,
How about taking a 5 in 1 paint tool and scraping the glue off your Bessey clamps?I can't think of any glue that has remained on my besseys other that a dab of polyurethane glue that foamed over,but it is on the side of a clamp head so no big deal.
Andy
Re: Why I'm doing this..... *LINK*
Jesse Cloud
>You can strip dried glue off your clamps with a wire brush on your drill. Here's an example, available at any hardware store....
wire brush
removing glue....
Bill Tindall, E.TN
>If the glue is white, hide or ordinary yellow, the only adhesives that should be used for interior work, hot water will soften them. In the furniture factories they hit the clamp racks with steam to strip the ubiquitous yellow glue they use.
I didn't understand your assembly description but in any case it seems to be interior trim work which does not endure any forces like furniture that is moved. So, it won't take much to hold it together and even nailed joinery could work fine.
Bob Burnet (NW FL)
>Soak the bessys in hot water, or wrap with a wet wash cloth. After the glue is soft, scrape off with an old credit card (Woodworkers of America membership card) or brass brush. Rinse off and dry. Then coat the Bessys with floor wax to prevent future glue sticking.
If you have TBIII....
Howard Acheson
>....you already have the longest open time adhesive the Titebond makes. The TBIII has an open time of 10 minute which is the same open time as TB Extend and TB white glue.
Removing adhesive from clamps is dependent on which glue you used. The TB Original can be removed by wrapping the bar in a rag wetted with boiling water or by heating the adhesive with a heat gun. TB II can be softened by heating with a heat gun. TB III can be removed except by scraping. There is no solvent and it is immune to damage by heat.
Once you get the bar clean, consider waxing it with a paste wax. Best of all is to cover the bar with wax paper or shower curtain rod covers.
TB II extend
walt smith
>Does sound like one of those late night ads, doesn't it? ;-) The data sheet says 15 minutes open time, 25 minutes assembly time. The thing to be aware of is temperature, the minimum recommended is 60 degrees. Not an issue this time of year but it can be in the winter.
http://www.titebond.com/ProductLineTB.asp?prodline=13&prodcat=3
Re: Titebond Liquid Hide Glue
>Outdoor water proof stuff...No good.
