Oak drawer Fronts
Oak drawer Fronts
Oak drawer Fronts
Jim vest
>I can't figure out what I'm doing wrong in this situation; I'm making drawer fronts out of red oak, various sizes,on the lowest speed that my Triton will run. I have not burn marks on the cuts, have a zero clearance insert (sacrifical fence), on a router table.
On the "cross grain" cuts, the cuts are about 1/8" deeper than the ones made with the grain. I have taken every precaution that I know of but each one turns out the same. I have made drawer fronts many times before (on another router and table) and not had this problem, what am I doing wrong?
Please help
Re: Oak drawer Fronts
Ed Mulligan
>Are you using a panel raiser bit or ??
Wood is easier to remove cross-grain than along the grain. In other words, the bit / router has to work harder on the long grain cuts. Sharp bit, slower feed rate and a smaller bite might help. But 1/8" is a lot! I'd also look into something loose or flexing in the table.
Need a little more info
>This sounds very strange. What kind of cut are you making? Straight bit? Molding bit? Raising a panel profile? Rabbeting for lipped fronts?
When you say deeper, do you mean deeper relative to the fence or to the table top?
Based on what I think you're saying, your workpiece is either not being held down flat to the table or tightly against the fence. The only other option I can think of is that the bit itself is moving relative to the workpiece. If it were the collet slipping, the bit would just keep cutting deeper and deeper. Is your router's height/depth adjustment locked out?
Ellis Walentine, Host
Re: Need a little more info
Jim vest
>Deeper in relationship to the "with grain" cut; in other words, there is a ridge on the "cross grain" side all the way across. It could be with some of the fronts, being 4" wide that the front may not be flat.
The bit I'm am using is a two fluted 3 1/2" raised panel bit from Whiteside. On one front the depth of cut was uneven; as I held the front sideways, the thickness of the board was not the same all the way across the board.
I don't think the bit is moving. I made three cuts to get the front to the correct depth that I desired.
Thanks for any help.
>It sure sounds like either the face of the drawer is not flat or that you are somehow putting more pressure on the end cuts than the lengthwise cuts.
If the board is tapered in its thickness, that shouldn't cause the problem you describe, but it means that you didn't get your stock prepared very well. Precision depends on getting things right from the get-go.
I'm glad you were able to make it work out in the end. I would still suspect slippage of the bit. You can check by using a fine marker to draw an indexing line from the shank of the bit to the collet.
Wish I could help more.
Ed Mulligan
>I've never used a panel raiser that big but if I did I'd take no more than a 1/16" bite per pass. You say you made the cut in 3 passes. How deep was each pass?
For panel raising, another technique (and it may help your situation) is to remove most of the waste with a table saw and then use the router bit for a cleanup cut.
Lee Schierer - McKean, PA
>It sounds like a problem I had with my router table set up. The router plate wasn't flat and longer parts would cut differently than short or narrow parts. The narrow parts all fit on the plate surface and would cut at one depth. The longer parts that spanned the plate and the surrounding table would cut differently.
Check your set up with a long straight edge.
Lee
