Nearly enough to make me take up basket weaving...
Dan Mitchell
>Saw this ad in the current "Woodcraft Magazine". Probably not a bad thing to have around just in case, but "...easy to remove when you get to the ER"??? YEEEEESHHH!
Dan Mitchell
Its Cheaper Than a Saw Stop!
Re: Nearly enough to make me take up basket weavin
>Two-year shelf life - so you know it's not just plaster of paris...
Actually, not a bad idea.
Re: Its Cheaper Than a Saw Stop!
Victor P
>Haaaaaaaaaaaaaaaaaa!
You haven't done basket weaving then..
>(I haven't either). However, the basket weaving class at the Folk School often works out of a room next door to the wood shop. The white oak basket class uses drawknives (and spokeshaves) to thin down the basket splints. Some of the other basket classes also use drawknives. Drawknives can be quite sharp and easily cut fingers (DAMHIKT).
..Just what I was thinking yesterday, George . . .
Yonak
>. . . when I wound up in the Emergency Room after sticking my thumb in the table saw blade .. the ER charge was less than the amount to fix a Saw Stop after a finger incident, but I must say, more painful and it makes it harder to type.
Most farms have this stuff around already
Stephen Kirk in Quakertown PA
>Have to use it on various animals. Especially if you go to far trimming a rooster's spurs or dealing with wounded animals. I think this shows up in most military med kits.
And
>I had a coworker who was a second generation basket maker. Her mom's one hand (right, I think) was permanently distorted from pulling the basket material tight. Imagine holding up your hand and having all the fingers pointing about 15 degrees off a straight line.
Not an ER medical issue, but still an orthopedic issue.
Guess I should have said "Stamp collecting"
Dan Mitchell
No - you get paper cuts then :).
>Just kidding. I had to split the log for the white oak basketry class once. I also had to loan them a couple of drawknives (and show them how to sharpen them). They make some pretty baskets.
