OT - shop light
OT - shop light
OT - shop light
>I'm rewiring the shop, getting rid of old wiring.
I put up a new shop light today - two 4 foot tubes, T8. It came with a five foot cord, way longer than the cord on the last shop light, which was about as long as my short term memory. Is this standard now, or should I allow for shorter cords in future in placing the outlet into which it plugs, and coil the extra cord out of the way?
At 64 watts between the two tubes, I'm not much worried about induced voltage in a loose coil of cord.
Re: OT - shop light
Re: OT - shop light
>Good Afternoon Bill,
Why izzit that the electrical cords are always six inches too short, ot six feet too long? Its always the case in my shop. I'd rather have the taskof coiling excess wiring and stowing it, than running a bunch of short extension cords to existing outlets.
When I moved my shop into our new home I brought the fixtures with me, about 12 in all. Sure enough, they had to be re-wired, and so did the shop. No way anybody can win over FATE! :<)
George
Re: OT - shop light
Re: OT - shop light
>When I built my shop I installed outlets in the ceiling to accommodate the 20 T8 twin 4' fixtures. It does make a lot of exposed cordage, but it does make for flexible fixture placement. I went with the borg el cheapo $20 fixtures, of which I have had to replace ballasts in about 6 of them. I used three-tube replacement ballasts, none of which have failed.
Clint
Re: OT - shop light
I think your shop may be a tad larger than mine
>I'm putting up one - 20 shoplights would just about cover the ceiling in my shop.
I'm going to have to go up and redo it slightly - the box says not to fasten it to the ceiling, so I didn't, but I did shorten the chain. Then I saw the toll-free phone number, where they told me I need at least 2" of clearance, to allow heat dissipation so it doesn't scorch/burn the wood joist. Now I have to add a bit of chain, as I'm under that distance.
Re: OT - shop light
Re: I think your shop may be a tad larger than min
Fred Davis
>Bill ,
If you want firm fastening of your shops lighting which is a good idea , make or buy some metal standoffs , look like lightweight channel iron , make the bottom the safe distance from the ceiling in width and the ears about 1/1/2".
Should be about the width of the fixture
FredD
