We value your privacy.
>I hired a crew of Aggies to lay some sod for me, and should have figured out a way to mark it, because I had to keep telling them to keep the green side up.
>On complicated projects, I usually had a detailed cut list with each different type of part labeled with a letter, a,b,c, etc. I'd mark those letters on the pieces before I even cut them to length, which was usually the first step. Once cut to length and before jointing and planing, I'd mark the same letter on the endgrain. After jointing and planing and squaring an edge and ripping to width, I'd very often use the old carpenter's triangle method as a quick reference as to how the pieces related to each other -- panel sequences, leg orientations, etc. If there were more than one sub assembly that were the same, I'd add a second (third, whatever) line on one side of the triangle to indicate which assembly it belonged to. When laminating, I would always mark the end of the billet before resawing, with a single cross line and a diagonal. That made it easy to sequence the laminates properly during glue up.
Pencil always worked for me for most layouts. Japanese craftsmen use a bamboo brush and an ink pot called a sumi tsubo, usually carved out of mulberry.
Dave Bair, Eaton Rapids, MI------WebKitFormBoundar
Guest
Re: Blue Tape------WebKitFormBoundaryaT6vsYmfUvr+X
>Actually, it will leave a residue. I found this to be true just last week; it took alcohol, mineral spirits and sanding to remove it from some white oak after an initial fuming with ammonia displayed it.
I have used 1/4" metal stamps, impressed in areas hidden after assembly, to mark mating parts like M&T,s.
