Way OT--HDTV hookup
Way OT--HDTV hookup
Way OT--HDTV hookup
Paul Blackwell
>I just ordered a 40" Samsung HDTV from Amazon. I've heard that hooking up and adjusting these TV's is a bit difficult. Being a dedicated do-it-your selfer, I'd like to do it myself, but I'm not sure I can handle it. Installation around here starts at $99 and I'm sure it will be more. I'm currently a Time Warner Cable customer. Does it take a special cable input to the cable box? I know it requires one from the DVD player, but I'm not sure which one to buy. Have any of you done your own install? Any info greatly appreciated.
Re: Way OT--HDTV hookup
Andy Lincoln,in Dearborn,MI
>Paul,
You may have to get a new cable box from your cable company that supports HD. The optimum output method would be via an HDMI cable from the cable box to the tv.If your DVD player supports upconverting to 1080p you will also need an HDMI cable from the DVD player to the tv.The only thing you will have to manually select each time you go between the dvd and cable box is the source input on the tv remote,also our cable box remote has the button/setting to do it as well.Do not rush down to Best Buy and snag an expensive HDMI cable they can be found on the internet way cheaper than the big stores want to sell them for,and I have not had any trouble with any I have bought and we have 4 HDTV's in the house and a couple of them have multiple inputs sources like video game systems,cable box,and dvd all hooked with HDMI cables.My son's TV has a switch box that allows 4 HDMI devices to hook to it and 1 output from there into the TV ,it automatically selects which port to used based on which piece of equipment is powered on,it was $30 well spent on Ebay.
Andy
Easy with HDMI
Mark Goodall - ATL- tooljunkie
>Look at the HDMI cables at the bottom on the link. They make installation much easier. You can buy then for $40 in stores or $15 online.
Depending on all the different components you have (cable-box,TiVo,DVD player, CD player, Xbox, Wii, etc) the hookup of your new TV can be done in a dozen different ways, so I won't cover them all here. But look at using HDMI cables if you can, both for quality and simplicity.
Also there are tons of how-to websites, etc that will help you. But remember, depending on the components you are trying to connect there will be many different ways to do it. Some people will plug all components into the TV and make the TV the center control unit. Others will use an AV/Receiver/amplifier as the center and then just hook on cable between that and the TV. Many options.
Happy Woodworking!
Re: forgot the link
Howard Norman
>Mark, your website has the best pictures and descriptions of the various cables that I have seen anywhere. Simple and easily understood. Job well done!!
howard
Dave Paine
>I recently purchased a 52 in Sony LCD TV. I have cable, but do not presently subscribe to the HD service.
I was intending to have my TV use the as-provided stand. So "installation" was lifting onto the TV stand.
Hookup of audio and video depends on your input equipment (audio and video) and output equipment (audio).
Since I do not know your equipment, I can only illustrate how my system is connected. I hope this helps. In my case I have a receiver which was purchased this last Xmas for the eventual intended TV purchase of a few months ago.
My cable is connected to my receiver which is designed to switch audio and video. I did this so I could switch video to a DVD recorder.
Video "out" from receiver is HDMI cable to HDMI input on TV. HDMI contains audio and video signal. DVI only is video signal.
My Blu-ray DVD player is HDMI connection to my receiver.
I have a PC laptop with VGA cable connected to PC input on the special TV port. Since VGA is video only, I also have audio input needed. I chose to use the Optical audio cable between receiver and TV. The PC is used for streaming internet radio and movies from Netflix.
As someone else mentioned, operate the TV at the higher resolution your equipment provides. My Blu-ray supports 1080p. The DVD recorder only supports 1080i. The PC video supports 480i / 720 p depending on signal from Netflix.
The biggest challenge for me was knowing which button on which remote is needed to make this all work.
Remember HDMI is both video and audio, so if you tell receiver you want the Blu-ray input, it will be "sending" HDMI signal. The TV will detect this, but until the Blu-ray player starts to generate audio (takes 30 + seconds) there will be no sound. Gets even more frustrating for the wife if there is no DVD in the BLu-ray player. Get blue screen and no audio. SOurce of some domestic disputes as remotes are used, discarded, but still not the expected sound or video. This technology is great when it works, but there is a lot to know, and especially to remember.
Good luck.
