Sending my Forrest Blade back to be sharpened
>I have a Forrest WW11 that has served me well for about five years. It seems to have been slowly getting dull, but the process has been creeping up so slowly I was not sure. I have cleaned it a few times and that helped. Today I bit the bullet and decided to send it in. I decided to clean it before sending it. It Cleaned up nicely. So nicely I almost put it back on the saw. The teeth were purty. I waffled for a few minutes, but then I looked at them with a lens. Not even a real powerful lens. It looks like I have been sawing rocks. There are numerous tiny chips and dings. Amazing. Now I have two problems, my blade is dull and I must be going blind.
What did you put your blade in to send it? I don't have whatever carton it came in.
Re: Sending my Forrest Blade back to be sharpened
>Hello Barry,
I wrapped mine in several layers of newspaper, got hold of a flat box and the USPS did the rest. When I got the blade back I took it to the Dentist, who affirmed it had nice teeth.
George
Dave Paine
>If you do not have the original packaging, just tape it down to a piece of cardboard larger than the blade, tape over a similar size piece of cardboard, to make a "sandwich" of the blade. Put tape around the edges, then whatever else you want for padding. The cardboard should prevent the blade from tearing any packaging.
Did this myself when I last sent in a blade for sharpening. I now keep the original packaging.
Jim Dillon
>Barry,
As I had thrown away my original packaging (dumb on my part), I went to the local borg and purchased a length of PVC tubing that woud be long enough to go around the blade. It was the clear stuff, that I know, from my lab days, as Tygon(R) tubing. I then slit it down one side with a sissors. Wrapped that around the blade and found a box to ship it off. It came back in a much nicer box that I have kept for future resharpenings.
Jim
Fred Davis
Barry , that is the case with Carbide, it is not sharp one day and dull the next unless you run something harder then it is through it.
I have no idea how often or long you use the blade, but it would be ready for a grind ,in well under a year in my shop and I spend considerably less time with the saw every day , then when I was in business.
On the other hand aside from Plywood , I seldom cut anything but hardwood on the saw.
FredD
