You're right!
John in NM
>I forgot about void filling, though I've never seen voids large enough to require filling in a well cut and polished granite - more typical of travertines and such. When you mentioned resin I thought of silestone and similar products.
Well, avoid ammonia if you like, but I still have to laugh at the folly of treating such rocks with kid gloves. Manufactuers recommend all sorts of silly sealers and careful use - I've no doubt that ammonia might damage their sealer, but since the sealer is, in this case, completely un-necessary, I have to say "so what?". In most cases the sealing chemicals are softer and more prone to chemical attack than the granite is!
As I've said before, some rocks do benifit from sealers, some do require periodic maintenance, but granite is not one of them. One day I'd actually like to see a piece of granite that has been damaged by some household chemical or another - excluding water + 200,000 years exposure. Thats about how long it will take the mica minerals to turn to clay.
That is a very nice slab! I like how the corners are just slightly rounded, goes well with the cabinet style where a large bullnose wouldn't.
