We value your privacy.
>Bri It`s all going to depend on the amount of amphrs. the cooler pulls, in otherwords how much power it takes. Then it also depends how many amps your battery is good for. Your battery should have something on it saying amphours. Look for them and it may give you an idea how long you are good for. Maybe someone else can explain it better than I can. But that is kind of the basics. Good luck with it.
>A battery is rated in amp hours as mentioned, but also at a given rate. For example, a battery might be rated at 50 amp hours at a 10 amp rate. This means that it could deliver 10 amps for 5 hours or 1 amp for 50 hours. Usually if you go over the stated rate, the life decreases, but the decrease is not specified. It might be that if you draw 25 amps on the example battery, you might only get one hour instead of the 2 the calculations would indicate. Very low draws might last considerably longer than calculated.
Look at the nameplate for the cooler and it should give a current draw. As long as this does not exceed the "at" rate for the battery discharge, you can take the amp hour rating of the battery and divide it by the draw of the cooler. This will give you the approximate time it will last.
>I've been using a Koolatron on an almost daily basis for years and only ran down a car battery once, when I left it on overnight. The battery was in reasonable condition and gave me several years of service after that incident. I have left the cooler on for up to 5 - 6 hours without killing the battery.
>Down here, in August, the interior of the car can reach 150�F+
I often leave a can of Ravioli inside in the morning when I park at a client, and by lunchtime it's hot enough to eat. In fact I've burnt the roof of my mouth a couple of times because it cooks so hot.
I would image that in addition the the answers everyone else gave on amps, etc, that no matter what calculations you did to figure the drain on the battery, that the season and the temperature of the car will affect it more than anything else.
>True. I forgot to mention that the ampacity is also dependent on the temperature. This is not to mention that there are a lot of other variables involved. What the calculations can give, however is at least some kind of an idea what you can expect for performance of a system. I sure would not want to bet my life on something that was designed to just meet the requirements. ;-)
