Making your own door/window trim?
>We do a lot of "trim carpentry" dressing up the flats and sets for the local community theater. Naturally we don't want to spend a lot of money (as we don't have any). If you have bought door trim, you know how pricey it can be.
The director for our forthcoming production would like six doors for the set. The old door trim has long since been destroyed by taking it off and putting it on various flats.
I don't want to go the "Woodmaster" route as that would be quite expensive. I was thinking about purchasing one (or more) router bits. I figure I could buy one for $70. I can easily buy 16' 1 x 4 for ~$3. The cost for 100 ft of trim would be under $100 for the lumber and the bit.
Does this sound "reasonable"? I was figuring on a Freud bit (99-468) - unless someone can recommend another.
TIA
Re: Making your own door/window trim?
>Good Afternoon JL,
I make my own trim/moldings. A couple router bits is all you need, provided you have the router/table.
George
Paint it!
John in NM
>I did a lot of theater work ages ago and was very impressed with what can be done with paint on a flat. Pick out a piece of molding, look at the shadows and the highlights, and just try to copy that on the flat. Should be really easy as molding is linear, so the shadows will be. Paint a ~3" stripe of your base color, mix in some white to paint the highlights and something darker for the shadow (beware of mixing in black though, it can end up looking too grey). Paint stripes for the darkest and lightest parts of the relief, then either wash or dry brush to blend the shadows and highlights into the field color.
>I've done my own trim, too, even without a router table (though a table does seem to help), and it stands up to closer inspection than a flat ever will.
Bill, avoiding the chores
