OT disolving duc tape glue
Philip Duffy
>In a moment of rash judgment I let my soninlaw put speaker wires across the kitchen ceiling and hold them in place with duc tape. Now, in trying to get the tape residue off the challenge has me whipped. I have tried 7 solvents, including WD-40 and graffiti killer, with little to show but a big smudge. Thankfully, SWMBO is on a family visit so getting it repaired in the next week is paramount! HElp?? Please! Any and all idea, save replacing the drywall ceiling, will be tried. Philip
Re: OT disolving duc tape glue
Tried Goof-Off?
Mike Farinella
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I think Bestine is the most effective solvent if you can find it.
Lacquer Thinner?
>Probably won't completely remove the smudge. Try Bin or Kilz to cover the smudge and paint the ceiling. (I like the old stinky Kilz better. Not so much the Kilz 2.)
you're screwed, probably
Bill Tindall, E.TN
>People often don't realize that removing something (glue, stains, dyes, ink, etc) is a two step process. The task is two fold, first the adhesive must be put into solution and then (the hard part) this solution must be removed from the surface. If the surface is porous I don't see a way of removing the dissolved adhesive.
For a non-porous surface the task is easy. Any hydrocarbon solvent will at least soften the adhesive enabling it to be rubbed off.
I think you will be looking at painting the ceiling, a fairly easy task.
Re: Here are some suggestions... *LINK*
DaleLenz
>but on dry wall???? Good luck, see link below. Wonder what affect dry ice would have.
Duct Tape 101
Duct Tape Glue Removal
Jack Prescott
>Limonene will remove almost any adhesive with great ease. Limonene is an extract from the peel of oranges, limes. I have access to limonene in its original form and it is a miracle cleaner for a lot of applications. Look for a citrus based cleaner such as "De-Solv-It", "Citrus Miracle", etc. which probably contain limonene.
"Goof-Off" is also an excellent cleaner but contains xylene which can be damaging to some materials to which it is applied so try it cautiously in an out of the way area first before proceeding. "Goof-Off" is a miracle cleaner for dealing with some cleaning situations such as removing scuff marks from golf shoes.
Frank
>Disguise it with bloodstains?
Philip Duffy
>Well, live and learn as they say. All you who offered solutions to the problem have been very helpful and I thank you! The WD-40 answer seems to be the most used and reliable. Getting the glue into a solution is very key and once there I found that the maroon scrubbies are best for picking it off the surface. The scrubbie tends to load up quickly and must be turned around and then washed as well. Now, for the real test; Will SWMBO see the remnants of the mess when she walks in the door? My painting skills (a joke) will be tried for sure. Thanks for all the input! Phil
A Little Late But
>I found myself in the very same situation except the goo (and tape was on the floor and the good extension cord. Started with MS, went to naptha, then to brush clearner, then...... looked up 3M trying to find an MSDS for the stuff to get a clue on the glue. Having no luck there, I called the 800 number on the inside of the roll . . .
"How do I get this gook off. please, miss?"
"Use an ammoniated cleaner. Citris-based cleaners also do well, Sir."
"So this is a water soluble gule on duct tape, Miss."
"Not soluble, but cleanable."
"Thanks"
It worked.
mm
Jack Prescott
>I bought some "Goo Gone Extreme" from WalMart yesterday. I used it to remove duct tape adhesive and it works great! A pint was less than $3.00.
