Ot; But cool!!
Ot; But cool!!
Ot; But cool!!
Roy C. Gryder
>For your next campfire. Start with a dry ( dry is important ) block of firewood 18 to 24 inches long and 10 to 14 inches in diameter. Stand the block on end and make 3 cuts with the chainsaw through the center and down about 3/4 of the length of the block. When you finish the top of the block should look like a sliced pie. Use the tip of the blade to make each cut a little deeper at the center of the block. Clear out all the loose sawdust. When it is time for a campfire stand the block on end and pour about 1/2 cup of lighter fluid in the center and light it. This will provide a small fire that will burn 3 to 4 hours unattended.
Great fun. R.
