JB Welded toilet tank, what are my chances?
Bob Entwisle in NJ
>Okay, so here is my dilemma�..
Simple job this morning, the upstairs toilet fill valve needed to be replaced, picked up parts, added a flush valve to the mix as I figured I�d have one big toilet rebuilding party and not have to worry about it for 5 or 10 years.
Removed the tank from the bowl, and proceeded to remove the fill valve and flush valve, tank was kind�a grungy, so I set it in the bath tub and proceeded to clean it out. Though I don�t recall it happening, I must have bumped it or set it down on the flush lever, anyway the result is a hairline crack across the flush valve and down the left side of the tank. RATS!
So while I know the final solution to this problem is going to be � If I�m lucky (NOT) I�ll find a replacement tank, otherwise a whole new toilet.
Being the optimistic type, I cleaned out and dried out the cracked tank and applied a large quantity of JB weld to the inside of the tank over the crack etc.
So what are the chances of the JB WELDed tank surviving to flush again???????
