Re: OT Cutting tile
John in NM
>If you have a dremel or similar tool, there are lots of diamond burrs available (Daniel Lopaki Co is a good supplier, though mostly the burrs come from China, so there are lots and lots of vendors). I wouldn't think they're balanced well enough for a router though. Do the bulk of the cutting with a wet saw or grinder, then finish up with the diamond burr.
Travertine is very soft stone, about as hard as steel, so carbide should work ok, but of course won't last as long as diamond. One of those structured tooth cutters would do best I think. Even a high speed steel cutter would make a few cuts before becomming irretrevably dull.
You can do a lot with a wet saw and a light touch, cutting mostly from the back side and sliding the tile sideways against the blade to smooth out a series of kerfs. If the saw is an undertable arbor its a lot easier as you can do all this with the tile right side up, but those saws are usually light and vibrate a lot more than a heavy rolling table saw where you would make the cuts face down and have to cut and look a lot. Either one takes a bit of practice, but its still feasible.
