OT - Installing tile outdoors - input appreciated!
Steve Silca
>Good afternoon,
I am planning on installing 12x12 tiles over existing concrete slabs/walkways. In the front of the house, it will be Blue Montauk Slate tile. In the back of the house it will be a porcelain tile. The idea is to cover the exposed concrete and give more of a finished patio/walkway look.
The cement surfaces are perfect - no cracks or evidence of heaving at all! However, the concrete is probably 30-50 years old and just looks old. Stable but old. I have a couple questions that I would appreciate input on:
1. The concrete DOES have small expansion joints - I was told by a professional to install a membrance to help prevent cracks and movement. At the Home Depot today I saw an 1/8" thick orange membrane (3'x116' for $87) that seems to be for this exact purpose called an "uncoupling membrane". I also saw a liquid waterproofing and crack prevention membrane that comes out of about a 3 gallon bucket and you spread with a roller for about $124.00. Does anyone have any experience with either of these and should I go with the orange uncoupling membrane in order to ensure no cracking in the future?
2. What mortar should I use? There is basic thinset mixed with water, basic thinset with the latex additive instead of water, and I now see there is something called "Flexbond mortar" which is twice as expensive and claims to allow for 1/16" of movement in the tile without cracking. Plus, this professional said I should look into a mortar called Keralastic made by Mapei. What mortar would you use? Would you use the additive instead of water?
3. Grout recommendations other than the basic stuff available at Home Depot?
Thanks!
