OT Raising the level of a toilet Flange Questions.
>I'm working on an old house for my cousin. Have torn out the bathroom floor, completely. Would like to raise the floor about an inch and a half.
The ancient cast iron has been modified. There is a black plastic/rubber insert inside the pipe and a white (PCV) closet flange is inside that. The black part is harder than neoprene but softer than ABS black plastic. This assembly may be glued in. I tapped on it and it is quite snug and does not move easily.
One, is this some sort of standard plumbing conversion kit? If so, what is it called? I like it, but it is too low.
Any suggestions on how to raise the level of the flange an inch or two if I break this out?
