We value your privacy.
>I'd like to make a small handscrew type clamp to use for holding small parts on the router table. 4 cross dowel bolts, 2 pieces of wood, and 2 threaded rods. It looks like a simple device to make but something just isn't right. What makes the jaws move? Are two of the bolts supposed to be reverse threaded or something? This has me baffled.
>Modern handscrews use "turnbuckle technology," with all the cross dowels threaded, and the two ends of the spindles being threaded in opposing directions.
It used to be possible to get kits for making handscrews - you might troll through the various mail order house online catalogs to see if these are still sold.
Old (wood thread) hand screws worked like this: the end screw - that is, the far end from the clamping end - was threaded into the first jaw it touched; the end of that spindle was turned down a bit to fit into a blind hole on the second jaw, to push against the jaw. The middle screw passed through a clearance hole in the first jaw IT touched and was threaded through the second jaw. Thus, the end screw served to create a fulcrum against which the middle screw was working (third class lever, see link; and I had to look up the lever classes, because I can never remember which is which).
You could get the same effect with less hassle by making a miniature leg vise: use some appropriate stock at the end, probably flat steel bar, and drill holes in it. This will let you set the rough opening in the clamp and provide the same fulcrum as the wood-screw handscrews. You could also use a threaded rod pinned to the moving jaw and passing through the fixed jaw (or vice versa; not having a picture, I'm visualizing a layout that may differ from what you've got), with a suitable nut between the jaws.
Having said all that, there may be simpler and more easily set clamping methods for a jig. A drawing, if you've got a scanner, would let the collective "us" confuse you more effectively.
>Thanks for the info Bill. I knew anything that looked that simple was going to be complicated. I have seen the kits and that's what gave me the idea to make my own. I figured why spend $15 on a kit when I can just buy a few pieces of hardware and build one from sctatch. Ha! I should have known there was a catch! The cross threaded rods. After taking a closer look at an old beat up handscrew I now see the odd threads. Guess I won't find anything like that in a hardware store will I. Oh well, now I have some neat cross dowel bolts for another project.
>They'll still be useful if you build it like the old wood-screw models; or, yes, for some other project. You do want the threads to be able to swivel a bit in the jaws.
The wood-screw handscrews depended on the mechanic knowing that the jaws needed to stay as close to parallel as possible; I suspect the flex inherent in a wood screw (compared to metal) permitted a leetle lack of parallel, but I recollect an older intro-to-woodworking book that warned against getting the jaws too far out of parallel and had a graphic drawing of the rear screw cracking over its length, intended to strike terror into the apprentice's heart.
I keep thinking there's a simpler solution, but it's eluding me...the joys of the middle aged brain.
