OT-removing Cast Iron(?) Tub...
Alan Young
Alan Young
>We have a candidate for the worlds Ugliest Bathroom. We have a claw-foot tub we plan to put in our bathroom but first need to remove the current tub(pink! ugh), and the plastic wall liner. We have a bid in from a contractor to remove/demo needed fixtures and re-plumb for and install the claw foot tub. The estimate for the work is probably reasonable but I want to see if I can save some $ by doing the demo work myself. The big question is the tub. This is on the second floor of 1895 era home. There is a tight corner on the only stairway. If I remove the tub in it's entirety I'll need to con several brutes into helping... Can a cast iron tub be smashed into smaller pieces with a sledge hammer?
-Alan
Re: OT-removing Cast Iron(?) Tub...
I'd wear hearing protectors if I tried it :).
>How about an angle grinder with a cut-off wheel? I've seen them power through just about anything.
Usual solution is a recip saw....
Kneale Brownson..Awaiting return to CO snows
>Cut it into panels you can carry.
Whoops: I saw "Plastic".....
>and didn't realize it was plastic surround and cast iron tub. Is there a window you can throw the tub out?
If not, I'd go for the angle grinder approach too.
Terry in Edmonton
>Score with an angle grinder and cutoff wheel, then break with a hammer. Noisey but fairly easy. Sometimes you can break them up quite easily with just the hammer. The hard part is hauling out the remains. Good Luck.
Ed Mulligan
>I recently got an estimate for a bath remodel. The plumber did say that he would smash the old cast iron tub in order to remove it. Don't know the details.
Smash it  *LINK*
http://www.ehow.com/how_5079104_replace-bath-tub-shower.html
GalenV in Iowa
>For the conventional shape tub (not pink!) I had good luck using the sharp side of my wood splitting maul as it concentracted the blow.
Upside down and ends supported on blocking. Wear a face shield of some type as the porcelain can really shatter. Ear plugs too!
Hope they can get the claw foot tub in as they are deeper for sure.
Older homes I lived in it seemed the bathroom doors were narrower than the bedroom doors. No way would you get the claw foot tubes out of them in one piece!
Galen
Hamish
>Alan, many years ago, when I was just a lad, I had the pleasure of breaking up our cast iron bath with a sledgehammer. It was white but the enamel had cracked and had stained in places. I seem to remember that we had lead pipes connecting it that I suppose went throughout the house. Breaking it up was great fun and I'm sure half the village heard it.
Looking back, I think the bath was the original one that came with the house, as the only way I think it got there was through the upstairs bathroom window. There was definitely not enough space to pass it through the house. When we broke it up, the old bath was not worth anything but scrap but nowadays, if the enamel could be redone, I could imagine it might be worth quite a penny.
Anyway, I hope you can break up your pink bath without too much trouble. An angle grinder and heavy hammer, not forgetting eye and ear protection, are probably your best weapons.
Good luck, Hamish.
Ken Oakley-Sunny St. Cloud, Fla.
>Cover it with an old rug or tarp and swing away-----
Steven Antonucci
Yes, from someone who has done it....
steve antonucci
>They break very easily into manageable pieces, but you are going to want to try to put down a tarp or something to catch the enamel. It shatters into a trillion razor sharp little shards and you'll need to sweep it out other wise.
Wear gloves to avoid cuts and eye protection, but it should only take about 10 minutes from the first blow to the last piece.
Steve
Bathroom demo in 2002, still finding shards...
Nick Tuzzolino
>Terry has the right idea. Also, no matter how hot it is that day, wear long pants. DAMHIKT
Bob Lang
>Smacking it with a sledge hammer is standard procedure. In addition to the cautions others have mentioned, don't hit the toilet on the back swing.
Bob Lang
I did it, too…
Rod Peterson -- Ormond Beach
>One of the very first destructive acts in my house remodel. Click on the “bathroom” link, although there are no actual pictures of the process.
Two very important things:
  • hearing and eye protection (as already mentioned), and…
  • be prepared for bounceback from a surprisingly resilient chunk of iron.
It'll take a few strokes before the first fracture, but from then on it's fairly easy to keep breaking things up. You'll also be surprised at how heavy small chunks of the debris are. Watch your shins.
Heh, heh—as Bob said, watch what's in the backswing area. That was actually demonstrated on an episode of Hometime. A toilet, just as he said.
Rod
Alan Young
I mauled it over and need ax no more questions.
Alan Young
Lee Schierer - McKean, PA
>As others have indicated you can bust up a tub with a sledge (20 pound variety), a hammer, even a 5 pounder, most likely won't do much except chip the enamel. You'll definitely want ear plugs and safety glasses. In addition cover the tub with a canvas tarp as the porcelean will fly with every hammer strike and those shards are sharp.
Been there done that, don't want to do it again.....
Lee
Pete in Holland, MI
>8# sledge hammer, glasses & all the protective gear mentioned. Start from the drain and work down the center. Yes, lots of enamel will be all over when done.
Good point on the toilet backswing.
Pete in Holland, MI
Alan Young
Wow Truly appreciate the destruction instruction
Alan Young
