Saw Stop meets Delta Faucet (OT)
Neal in San Jose
>Last weekend I installed a new kitchen sink and faucet. The only woodworking content was replacing the soggy, rotten, bottom of the sink cabinet caused by a leaking angle stop. SWMBO purchased a top-of-the-line Delta faucet with a feature I originally thought would be pretty useless. Turn on the faucet like any other one and get the flow and water temperature set. Then touch any part of the faucet and it turns off. Touch it again and it turns back on at the same flow and temperature. Off, On, Off, On. Actually pretty useful when rinsing things off before putting them in the dishwasher, and I think it will save many gallons of water. I don't know if it reacts in 5 milliseconds like my Sawstop, and I'm pretty sure it would pass the "hot dog test" (I can't test it because I haven't bought a hot dog in probably 2 decades), but I've already gotten used to it, and I like it a lot! I'll just have to remember NOT to touch the spinning blade on my Sawstop to turn it off, LOL!
Re: Saw Stop meets Delta Faucet (OT)
Howard Acheson
>You can save a lot more water by not pre-rinsing things put into the dishwasher. It's just not needed. If you have large stuff left on the dishes, just use a silicone spatula and scrape it into the disposal or garbage bag.
I agree with that
Dan Mitchell
>it can be a very significant amount of water, but I do think it varies with the dishwasher, with newer ones seeming to require less pre-rinsing, and also having a food grinder to deal with the bits that get rinsed off in the machine.
I've always wondered why there are no home faucets which could be pre-set for temp & flow like the Delta Neal mentions, then activated with a small foot switch in the toe kick area. Would also save a ton of water in the bathroom while shaving, brushing teeth, etc. Would be very easy to do, I've even thought of coming up with my own, using a solenoid in line with the spigot.
Dan
Dan! You gave away your secret!
Stuart Hough
>Now the Chinese will rush to market with a 25 cent fixture that Wally-world can sell for "just $9.99"! It'll be the CFL lightbulb all over again!
Re: I agree with that
Chris Friesen
>Foot switched valves for faucets do exist and are used in some hospitals. They're expensive though, due to their rarity.
They make a lot of sense though, and I wish they were more commonly available.
But, what if...
Ralph in Huntington Beach
>...you don't do the dishes after every meal or even every day? I'm a single dad and usually don't turn on the dish washer until I'm nearly out of dishes. I have a Kitchen Aid that's less than a year old and does everything, but I still rinse the gunk off, since it might be a week until I turn it on and I'm afraid that if I didn't, everything would be dried on to the dishes and NEVER come off.
And don't tell me to do the dishes by hand...I love that dishwasher and the water issue is a non-issue with me!
Re: But, what if...
Dan Mitchell
>Ralph - Our household is only 2, my wife & me. We have a Kitchenaid KUDK031TBL0 (no, I don't have that committed to memory, I just checked ;-) which is about 1 year old. We often go at least 2, 3 days w/o washing, & it generally removes everything. Sure, there'll be the occasional gunk that needs to be re-soaked (filled w/water) in the sink & maybe brushed a little before a re-wash, but it really is very rare. One thing I've found is if you put the dirty dishes INTO the machine fairly quickly, even if you're not going to run it for awhile, because of the relatively moister environment in the closed machine, crud doesn't tend to dry on as much.
Dan
Single persons water saver--------Paper plates!
GalenV in Iowa
But, Neal, what the hey?
Eddie Pacheco: Antioch, Ca.
>Now you are using electricity or batteries on something that was passive. You're earning too much money, Dawg.
Re: But, Neal, what the hey?
Neal in San Jose
>This is from a guy that has too many wheels on his motorcycle?
I have that faucet also.
Carlos Clarke
>It's the Delta Pilar faucet. Overall it is a great faucet.
Sometimes you get a double hit when you touch it and it
goes on and then off immediately. But I find that often both
my hands are either covered with something or carrying
something. Then I just bump the faucet with the back of my
hand.
The spray head fits back into its socket with a magnet
instead of twisting it in place. That was the main reason
for getting it. It is easier to replace so it isn't left
hanging out of the socket.
The only problem is the frustration when you go to different
faucet and bump it and it doesn't go on. :)
Re: But, what if...
Howard Acheson
>Not running the dishwasher every day should not be a problem with any dishwasher made in the last 5-10 years. They are designed with a pre-wash cycle that softens and removes any solids. After that cycle, the regular washing cycle runs.
If you have a soap container that has two compartments, the smaller compartment holds the detergent used in the pre-wash cycle.
The new energy and water efficient dishwashers work quite well according to Consumer Reports.
BrianA
>What makes it work?
Brian
Re: I have that faucet also.
Neal in San Jose
>Yea, kinda like when I come home from work and wonder why the lights don't automatically come on when I walk into a room, LOL!
Neal in San Jose
>There is a module, maybe the size of a deck of cards, that has two low voltage electric water valves that are controlled by (I'm guessing here) the same technology that the Saw Stop uses to fire its' brake. The module mounts under the sink with 4 "C" cells to power the water valves and the sensor. It is pretty compact and surprisingly easy to install.
I used it last night while washing stuff that doesn't go in the dishwasher like the wine glasses and wood handled knives and the more I use it the better I like it.
Thanks Dan...
>...I have a KUDT03FTWH3 (I just checked also) and you make a great point about the moisture level in the washer...it is a sealed environment and food drying out and becoming permanent would not be much of an issue. I might still pre-rinse after eating eggs, but I do believe I'll give it a try...and my daughter will also love you for it!
PS. I go through paper plates like there's no tomorrow; I buy them in bulk at Costco!
Ralph
I just eat over the sink!
Just think
Dan Donaldson
>If you recycle in your area, use paper plates, and use food from cans, you end up throwing out the dinnerware and washing the garbage ;-))
I have a question
GalenV in Iowa
>If you have a cat and you go off to work for the day and the cat decides to get up on the counter and brushes the water faucet and the stopper just happens to be in place. How much water can overflow in the kitchen before you get home and shut it off. I hope they have an automatic shut off after so much water has been run into the sink.
Even though my kids always had cats you can tell I am not a real cat lover.
Galen
Doesn't require high-tech
Dan Mitchell
>A friend of my father when I was a kid in the '70's had a couple cats, and a "regular" kitchen faucet with a long central arm for adjusting the water (as opposed to a couple of knobs). One of the cats would routinely get up on the kitchen counter, turn on the faucet, play with the water until it got bored, then jump down, leaving the tap running full-blast.
Never much liked cats...
Dan
It auto shuts off after 4 minutes
Carlos Clarke
>But if a cat is a problem you can just close the handle.
The handle is normally set in the on position for water
to flow. With it closed no water will flow.
