We value your privacy.
>I'm looking for help in designing my NEW workshop.
I'll have one about 14' by 22' built on to the side of my garage.
I need specs on placement of major tools, clearance around the tools, lighting, electrical outlet placement, dust collection, HVAC, overhead or hinged large door.
I'm sure there are other topics I haven't even thought of.
If you have suggestions/recommendations I would really appreciate your input.
If you are in the Dallas, TX area do you have a recommendation on a general contractor, concrete guy, electrician and/or framer?
>Tom - when we expanded our garage to a 3 1/2 car space I laid out the "shop" space on a large piece of tag board with all the windows, doors and electrical outlets shown. Then I made paper cutouts of all the major tools, table saw, band saw, jointer, dust collector, etc, etc, etc. With the cutouts I included the largest size material I was likely to use on that machine as well as clearance on the infeed and outfeed sides. Don't forget to include cabinets that you have or might add.
With those cutouts, I just started arranging and rearranging tools and spaces until I came up with a workable plan. Moved the machinery ONCE and haven't moved it again in the last year and a half.
I spent a grand total of $12 on the tag board and some markers and it actually worked!
I tried a couple of the shop layout programs (Grizzly, Home Architect and even AutoCad) but the initial layout and changes were just too cumbersome. The tag board and marker solution was easy, cheap and, at least in my case, resulted in a surprisingly workable plan.
There is a lot to consider with this project. I would suggest reading "Setting Up Shop" by Sandor Nagyszalanczy or any similar book you can find. Once you have read it, come back with more specific questions. You really need to consider YOUR work flow, YOUR work style and YOUR machinery (current and future). Plus the ability to keep your layout as flexible as possible. If you go through the Shop Shots, you will be able to see what works for others.
>The Dream Shop planner on the Grizzly worked for me.
Consider the "inflow and output" of your tools. You may also need to rip or crosscut a piece of plywood. Consider the maximum length (and width) of lumber that you may be ripping, jointing, planing and crosscutting. Consider how you are going to get power to the tool and collect dust from the tool and plan accordingly.
My table saw is in the center of my shop (17.5 x 25). The other tools are around the periphery. My saw is placed so I can crosscut a 16' board and have two 8' pieces. I've got my jointer and my bandsaw on mobile bases so I can swing them out if I need to joint a long piece or resaw a long piece.
>Like others, I think software is too big a tool for this problem. What item is the center of your workspace? For at least 80% of woodworkers, I'll bet it's either your table saw or your bench. For me it's the bench. That goes where there is plenty of space all around it to do everything I do there.
Everything else serves the bench, with a little thought about how much infeed and outfeed space the stationary tools need.
But I've been in plenty of shops where the table saw was the heart of the shop. In my experience, the guys who set up such shops use a lot more plywood than I do, and so need 8' more or less on either end of the blade.
In my opinion, once you've figured out whether the bench or the table saw is the heart of your work, you're at least 80% of the way to a shop layout. So I have a lot of sympathy with a piece of paper or just shoving things around as substitutes for software, FWIW.
