Resaw problem/question
Joe in a Cleveland Suburb
>Hello.
Last night I was trying to re-saw a piece of 5/4 walnut approximately 9-1/2 x 15. In less than 2 inches into the cut, it was starting to drift so quit right away. I had a white line down the center so I could watch if it was drifting. I was going very slow with the cut letting the blade do the work.
I've done this many times without a problem. Any suggestions on what I could check before I go any further?
My setup:
  • Jet 14" BS with riser.
  • 105-1/2 022 3/4T HP Swift Wood Slicer (a couple years old)
  • Tall auxiliary fence
  • Checked fence is square to the table
  • Walnut is planed flat on the side that is riding on the fence
  • Walnut is jointed on the edge that is on the BS table
  • Adjusted fence for run-out by using a piece of ply with a straight line on it and adjusted the fence to the cut
  • Two things I am not sure about is if the blade has enough tension and if maybe the blade is dull(?).
    Thanks for any suggestions.
    Re: Resaw problem/question
    Kneale Brownson..Awaiting return to CO snows
    >I'd vote for a dull blade.
    Lee Schierer - McKean, PA
    >You could have either a dull blade or not enough tension. I would add a bit more tension, but would also make or buy an auxiliary fence (see photo) that allows you to pivot the board so that you can stay on the cut line as you resaw. By pivoting the board you should be able to resaw and not have to worry so much about blade drift.
    Lee
    Ed Mulligan
    >Yep, it's blade dull or tension low or maybe you goofed up the drift / runout angle for the fence.
    Drift
    >If you're feeding the wood directly into the blade using a fence to guide it, chances are that the tips of the teeth on one side of the blade are worn more than the ones on the other side. This frequently leads to the "drift" that so many people talk about. There are a couple solutions. The one I like best is the "point fence" solution, where instead of a fixed fence, you provide a vertical point fence parallel to the blade and perpendicular to the table, usually on the outboard side of your bandsaw table. This fence ensures that your workpiece, as it passes the tips of the blade, is at a certain distance from the fence.
    This method requires that you guide the wood as you feed it. My trick is to a) keep the face of the board firmly against the vertical fence; and b) cross your eyea a little so you can see that the heeling end of the blade is centered in the saw kerf. If it is rubbing on one side of the kerf or the other, adjust your tracking so that the back of the blade remains centered. You'll be amazed at how well this works.
    Ellis Walentine, Host
    What do you mean...
    Joe in a Cleveland suburb
    >by "on the outboard side of your bandsaw table"? I can't picture in my head what you are talking about.
    I just now left the bandsaw again. I went and double checked things and increased the tension on the blade. I turned the saw on, started to cut the board, and the blade came partially off the wheels. The saw came to a screeching halt with the blade rubbing against metal...
    Even so, the teeth sure seem sharp to me.
    Joe
    I had that happen to a TimberWolf blade
    walt smith
    >It seemed fine. It wasn't. Thing would not cut straight for love nor money. A new blade made it all better.
    Re: I had that happen to a TimberWolf blade
    >Well, since the blade came off and hit all kids of metal, the blade if definitely ruined.
    A new blade is in my future.
    Thanks.
