REAL MILK PAINT
Pre-Finish Door Raised Panel - HELP!
howard
>I can't seem to get an answer to the following - if the preference is to pre-stain a raised panel, when the door is glued up, how do you prevent the staining of the frame from messing up the prefinished panel? Is the panel supposed to have an initial seal coat to prevent this, or do most of you mask up the panel? I'm trying to understand how the panel can be prefinished without messing it up during and after the frame glue-up.
thanks
