Prefinished Plywood
Prefinished Plywood
Prefinished Plywood
Bob Boswood
>I have built a few kitchens over the years, mostly for myself and relatives. I always used 3/4 birch plywood. I am planning on using prefinished birch plywood on this project, thinking to save time not having to finish the interiors of cabinets. My question is will pva glues bond to this prefinished plywood sufficienttly. I build the cases with biscuits,screws and pva glue. Is this overkill?
Re: Prefinished Plywood
Glue wont stick to surface
Stephen Roth
>One of the advantages of the prefinished stuff is that glue will not bond to the surface at all. It is pretty much as slick as melamine. The glue just peals off. Otherwise, it workes just the same as regular plywood with biscuits, etc. In situations where I did need to surface bond, I have sanded off the finish ... which was not that easy to do!
Also, I have found very few places have it. Hope you have better luck.
Glenn Madsen near San Francisco
>I've used Columbia prefinished and found it to be really good. The Chinese garbage is still potatoe chip shaped garbage that smells like fish gut glue. Not what I want in a kitchen.
When you use biscuits, Kreg screws, glue and 16 ga air nails, the cabinets tend to stay together, even if the glue only holds where there's no poly. And I DO like not having to spray the insides, or wipe them down with 4 coats of wiping varnish.
Can you tell I don't like to finish cabinets much?
There's a pro supplier here in Oakland that I buy through. Easy peasy.
