Not quite that - should be easy fix
>"With the absorption of Alltel by Verizon, Alltel decided to close down its email server for those of us using an Alltel aircard for internet connection, so now my email won't work through that setup.
I only can use my dial-up retained as a backup in case Alltel had problems to send emails.
How do I get a wireless email system?
According to a letter I received got Verizon Wireless, this is what's going on:
Verizon is closing down it's SMTP (outgoing email servers) at the end of August. So if Alltel was purchased by Verizon, it would like affect Alltel the same way.
Most likely your wireless device (PDA or laptop) was receiving email from your incoming (POP3) server such as: pop.whatever.com or mail.whatever.com and was sending out email using the Verizon outgoing (SMTP) server. Now you will need to use your own SMTP server, which would be something like: smtp.whatever.com or smtpauth.whatever.com or possibly even mail.whatever.com
What you need to do is go to the company that provides your you@whatever.com email, and see what SMTP server they offer you to use.
Of course, without all your details, I can't tell you exactly what you'll need to do. But in general.... in the past you probably used pop.whatever.com to receive email, and smtp.yourISPserviceprovider.com to send email. Now you'll need to use smtp.whatever.com instead.
Happy Woodworking!
