Finishing with shellac
Matt Papania
>I am refinishing a mahogany writing desk.A friend of mine recommended using a trans tint dye in a 2 pound cut shellac to use as finish.This is my question,since this was the first time I ever used shellac and the finish sets so rapidly,I had some problems. I have some runs down the side of the desk and some puddling in the finish on some drawer fronts.There are also some small areas were I missed with the shellac/stain mixture. Can I use denatures alcohol with a pad annd mineral oil and even out the finish?Can I put a polyurethane fish over this? Please help!! Thanks Matt
Re: Finishing with shellac
Kneale Brownson..Awaiting return to CO snows
>French polishing they call it where you use a pad and alcohol. Should work for your problem.
I definitely would apply a more durable finish for a writing desk.
Need More Info
>Hi Matt,
First, what kind of shellac have you used? Makes a big difference when topcoating with a different film finish.
How are you applying it?
Transtint dye works well in shellac as a toner, but used in anything other than light applications can lead to lap marks and blotches.
The runs can be sanded off when properly dry, although you you will have some hassles getting the color to match.
Are the drawers dished in some way that caused to liquid to pool?
Matt Papania
>I am using an Garnet dewaxed shellac 2 pound cut with the transtint dye.I was told to brush it on.The reason for the pooling of the finish is that the front of the desk and drawer fronts are surpentine in shape.
More Info
>Okay
First, you've got some work to do on the drawers; namely an alcohol bath/rubdown to redissolve what you applied to get the excess off. You can brush shellac, but it's hard to control; padding (similar to french polishing but without the oil) is much easier and more accurate. Shellac sprays so well that I suggest you consider it; especially if you're using dye to color your coating. Key here is many light coats with patience.
2. If you're looking for consistent color, you may also find yourself in the rinse-and-reapply mode where you have those drips and runs. Sorry. Good part is that you can reuse what you rise off after letting it evaporate a bit. BTW, I prefer 1-1/2 lb cut, but that's just personal preference.
Now for the good news:
The old adage is that "shellac sticks to everything and everything sticks to shellac" so, because you've used dewaxed product, you can topcoat with poly once your shellacing is done.
With your desk nicely sealed and tinted with the shellac, let your item get very dry for 3 days or more. You can then consider the poly. Rather than going for the oil based stuff, consider a coat or two of an acrylic waterborne formulation such as General's Enduro clear poly or Target's 9000 poly. Using good nylon they brush and level well, but with an HLVP spray, they'll go down like glass with a little practice. Being water white and clear, they won't change the color of your piece and you'll only need to apply them to the top for durability.
Hope this helps.
Great post, Mark. Thanks.
