Filling stripped screw holes
mamc
>Someone... dropped the water ski, and the six screws holding the back fin in were popped ( ripped) out.
Looking for suggestions as to how to fill these now stripped screw holes so I can re attach the fin.
Bigger gauge screws may be an option to get some grip, but I would like to fill the holes to provide maximum strength. Skis are not wood they are some sort of composite material.
I dont think the old "fill the hole with tooth picks" is going to work here. Any suggestions on what sort of material or method might bond in and fill the old screw holes to provide enought grip to re screw?
Thnx
mark
Re: Filling stripped screw holes
Bondo?
mdclor
Toothpicks
>and thin Super Glue (cyanoacrylate a/k/a "CA"). If you don't have any CA, find a turner; we buy the stuff in quarts. What you're looking to do is make a fiber/resin composite in the holes that will bod and give the screw threads something to grab. The CA will penetrate thin slices of the wood fiber much like doing fiberglass. Of course, if you have some glass cloth and thin epoxy, you can do the same thing.
Another possibility
Robert R. Clough - Thorncraft
>I'd probably get some specially made screw hole fillers - made of wood - Rockler, perhaps. Then, never having any success with instant adhesives, I'd use epoxy. Of course the large Bamboo sticks pointed on a sander should also work - and being Bamboo, they just might hold better.
PC-7 Epoxy paste
GalenV in Iowa
>You did not say what size fasteners where used or how badly the fibers are torn. It would help to know the thickness as well.
If the ski is composite and it tore out fibers you may need to drill out to get to solid material and not just try to fill the holes as is.
You might use threaded brass inserts with brass machine screw in a clean cut hole. There are expansion inserts that are designed for plastics that would work as well. One brand is by Tri-Star. You may even find them at a marine supply store for fixing other composites.
Would need to see if you can match diameter to new cleaned hole and thickness of part to compare to any insert.
Galen
Jesper, Denmark
Jesper, Denmark
>Assuming the skis are not cored, I think you need to drill out the holes, fill with epoxy and some filler like high density silica, Drill the holes undersized and use selftapping stainless screws.
JB Weld
Bill Tindall, E.TN
>I don't know if this will work but this stuff has performed miracles for me in the past for things like this job. It seems to me that some sort of tough resin is going to necessary to fill the holes and bond to the original material. Some filler in the resin will make it stronger. Hence, JB Weld came to mind.
Fred Davis
>Why not check to see if you can reattach the fin with stainless steel or Marine Bronze nut and bolt with locktite on the threads.
Flat screw head set flush with top .
Should do the trick permanently.
FredD
mamc
>Thanks guys great suggestions as usual.
After another inspection I think I can get away with a heavier gauge stainless #10, 1/8" longer screw with some generous applications of marine adhesive and sealer for what its worth.
Did a test on one hole with the larger screw, and there seems to be a good grip happening with the larger diameter .
There are six screws on the fin fitting so should be enough to hold...if not, the 15 year old "someone" who dropped the ski is likely going to wipe out....which would be justice !
Failing this I'll be back to the suggestions.
Thanks again
Mark
Re: Toothpicks
Barbara Gill, Remlik VA
>I use the toothpick/CA glue method with great success.
Re: Toothpicks/5minute epoxy
Justin Szeliga
>I keep 5 minute epoxy on my truck for just this problem. Fills the hole, mixed w/a piece of cedar shim then jamb the nice soft cedar stick into the hole, let set, then trim off when hard, run a screw in the easy to screw into cedar.
Peace
JJS
