Kitchen Cabinet Question
Bob Henderson
>Is there a standard height off the floor for wall mounted kitchen cabinets? These are 30" tall if that matters.
Bob Henderson
Re: Kitchen Cabinet Question
>18" up from the top of the base cabinets, or aproximately 54" from the floor.
Clint
Fred Davis
>Bob ,
A couple of things about your cabinet question.
Assuming a eight foot ceiling as the standard does, your uppers can be a full size 42" tall , next size is 36" tall , then 30" and 24".
This only applies to uppers over a standard base cabinet height of 36" with the counter in place.
Your cabinets being 30" tall robs you of a cubic foot of storage per running foot of cabinet.
This is pretty typical of apartments, and other multiple unit housing.
Also some interior decorators and Architects who should know better , like a soffit above the upper cabinets, extending generally six or twelve inches down from the ceiling.
In most cases you will find the the 30" upper stopped twelve inches short of reaching the ceiling.
Regardless of the size of the upper cabinets , given a eight foor ceiling and a 36" counter height , you will want to wind up with 18 inches clearence between the bottom of the uppers and the top of the counter.
Anything less then this , will give you trouble with small appliances like coffee makers, mixers, fitting beneath the uppers.
Hope this helps.
FredD
Kenny Heermann
>We are starting to redo the 25 year kitchen and are having a hard time picking out everthing. We have looked around stores in the KCMO area, including the box stores. I have did searchs on the web but really have not yet found any sites that have good pics. Any link ideals would be a big help, Thanks for your time.
Re: Check out RTA Cabinets!!!
Dave Anderson (PacNW)
>RTA Cabinets is a division of C.S. Hardware, A Wood Central sponsor. I am in the process of doing a complete kitchen remodel from sub-floor up. I went with RTA Cabinets on the recommend of several WC members. This is one of the best things I could have done. The Cabinets are fantastic! I went for the Manchester Elite in oak. The Price delivered to Seattle was 70% less then the orange Borg and far better quality. I would recommend them to anyone. The Gal that came out to bid on the granite counter-tops could not believe they were mail order and wanted to know where to buy some for herself. If you call them, ask for Peter and tell him you got the info on Wood Central
Good Luck'
Re: riegseckercabinet.com
Moses Yoder
>they have some pics of past jobs that will perhaps give you some ideas.
>Notwithstanding all the negative comments from folks who have never installed or lived with them, check out the lines that IKEA has to offer.
Clint
Jim Follette in Fayetteville, NY
>Dave, what are the carcasses made from?
Fred Davis
>I would first check out some cabinet shops in your area, if you find a small shop that specializes in remodels , plan your cabinets with him and if they don't do the installation , (many don't) ask for his recommendation on a Finish Carpenter that he uses for installation.
If that doesn't work , the Lowes in this area(Salina , KS) have a good grade of stock cabinets , but you will pay dearly for them and the flexibility you get with the cabinet shop won't be there.
On the other hand Lowes is a good place for appliances.
I imagine the stock cabinets are pretty much the same from store to store.
FredD
>The Boxes are made from 1/2" plywood and are finished both sides, Face frames and raised panel doors are solid 3/4 oak. The drawer boxes are 5/8 wood dovetailed at both ends. The slides are concealed soft close full extension. I bought 17 cabinets, 2 refrigerator panels plus the toe kick skins, 6 extra filler strips (used 5), crown molding and 1 qt matching stain and a touch-up kit The price including freight was $2738.00 delivered to my house. the time from order to delivery was 8 days Wisconsin to Seattle. They carry 16 or so different lines of cabinets with varying options and price ranges. The only complaint I have is the assembly instructions are a little vague
Dave
Re:Good Price!
>Dave,
That sounds like the cabinets we custom make for our Habitat houses except we use cherry for the face and door frames. We use prefinished 1/2" birch ply. Our materials alone for 15 cabinets runs about $1100. Sounds like you got a good deal!
Jim
Hieght answer, and RTA factual opinion
John Cotten, Scribe Mark Woodworks
>In reply to your question of the upper cabinet hieght, I work with my customers to assign a hieght based on their hieght. We usually run our cabinets between 19 to 21 inches off the countertop. Many people have their coffe makers, toasters, blenders under their cabinets, coffemakers quite literally need room to let off steam, toasters or toaster ovens heat. Also if you put in under counter lighting, the lights frequently wind up right on top of what ever is under the counter.
If you are a tall individual, raise the hieght of your uppers and your lower cabinets.
I occassionally sell the import cabinets RTA from 3 different sources, these have become a required evil for me because some of my contractors do not want to invest in better quality cabinets. They LOOK great, but 1/2" ply staples, metal or plastic connector plates and MDF will never take the place of glued and screwed together 3/4" plywood and solid wood, whether frameless or framed cabinets.
Additionally, a reasonable custom shop will not be much more that a some of the RTA cabinets, especially if you consider the cost of installation, assembly, and delivery for the RTA cabinets.
If budget is your main consideration, go for the RTA, but know that you are going to start having some problems with them in just a few years. If you are looking for a good investment, go to a SMALL custom shop. Look at the equipment, don't consider cleanliness a main consideration, most small shops will always have dust and boards stacked around. We are usually the guys who are busy and can't afford the time to do a major cleaning and organization every day.
Expect to pay 50% up front on the contract with a custom shop, this is normal, 30% upon delivery, and the balance when installation is finished.
Another thing, make sure you know what kind of hinges and drawers slides you are getting. These are key to longevity of the life of your cabinets. I am not completely sold on bump-opening slides, or soft closing slides. My primary slides are 100 lbs. KV full extension slides, the gadgetry of the soft close, etc are nice, but remember they are extra parts to go bad or have a problem later on. I use Salice soft close hinges exclusively. They are in my opinion the best made euro-slide hinges on the market. Reasonably priced, and easy to adjust.
Email me if you have any other questions. I will be glad to help you any way I can.
Should have said Euro-style hinges.
Kenny Heermann
>Hello All, Thanks so much for the replys
